May 15, 2025, 07:07:08 07:07
Author Topic: help!! crack for: mikroC for dsPIC  (Read 13563 times)
kahtan
« on: May 24, 2006, 02:26:10 14:26 »
if any one has a crack for: mikroC for dsPIC ?? plz send it to
kahtan.jweer@gmail.com Shocked
parallaxis
« Reply #1 on: May 24, 2006, 08:26:16 20:26 »
1. Use SEARCH before asking: http://www.sonsivri.com/forum/showthread.php?t=930&highlight=dsPIC+MikroC
2. Don't ask "please send it to me". Say: "Please share it with others..." Smiley
tavioman
-Receive: 17
« Reply #2 on: May 24, 2006, 10:03:40 22:03 »
Why some people don't read the rules firs???
- Brain juice -
sly_fox_2006
« Reply #3 on: May 24, 2006, 11:53:27 23:53 »
Quote from: parallaxis
The key generator is only for basic and pascal for dspic......Sad
parallaxis
« Reply #4 on: May 26, 2006, 02:17:30 14:17 »
1. DL MikroC for dsPIC v. 1.0.0.0 from Mikroelektronika site
2. Try to use key in dakey.zip - it's key from Mikro C for PIC, just renamed
3. Hope it works...
I tried it just now - you can see results on picture attached here. Source code of my experiment and generated HEX is attached too...
msamar
« Reply #5 on: May 28, 2006, 08:31:26 20:31 »
this licence dosnt work its just file
it can passed limit demo and success compiling but the hex file is damaged
try other one
ragrdes engineer team
msamar
« Reply #6 on: May 29, 2006, 10:19:05 22:19 »
if you program hex file to target micro( dspic )the program dosnt work
as you can see its very easy to test hex file
tavioman
-Receive: 17
« Reply #7 on: June 12, 2006, 07:34:25 19:34 »
If anyone succesfuly cracked mikroC for dsPIC, please share the crack with us.
Thank you very much.
- Brain juice -
robban
-Given: 34
-Receive: 38
Warrior
« Reply #8 on: June 15, 2006, 06:04:39 06:04 »
This is actually meant for MikroC, but works also for dsPIC. At least those examples I compiled. Try it out, boys and girls...
Code Warrior
Yuriy
« Reply #9 on: June 16, 2006, 11:44:32 23:44 »
Just a quick question, I can't seem to DL any of the attachments.  Am I missing somthing or do I need to start riding the short bus?  Many thanks.
paulosa
« Reply #10 on: July 27, 2006, 11:25:51 23:25 »
We are waiting for another crack for mikroC for dsPIC
spillaccio
-Given: 42
« Reply #11 on: July 30, 2006, 10:43:21 22:43 »
Hi everybody.
I needed a crack too for MikroC DSPic Compiler, so I tried to do it myself.
Maybe luck, maybe for experience ( :p ), I found out something.
Try this out, and tell me if you found it useful.
If you will, I will use ... LUCK ... to find new cracks you and I could need...
Thank you everyone -
SpiKi Corp.
Spillaccio
relsys
« Reply #12 on: August 23, 2006, 11:06:54 11:06 »
hmm......, I don't think this patch works.....
the hex file is different after each build.......
there is some more in compiler protection
mizk_electro
« Reply #13 on: October 04, 2006, 06:44:56 06:44 »
Hi everybody.
SpiKi Corp.
Spillaccio
I cannot see any file to be download or I'm missing something Huh
Thanks for any help/info.
