You think I am funny guy huh?
May 20, 2025, 03:32:57 15:32
Author Topic: rs-232 on pic16f876a  (Read 6355 times)
Pikoko
« on: May 26, 2008, 12:29:38 00:29 »
how would i program serial into that pic in picbasic pro. iv had someone tell me how to do it in proton plus but i dont have that.
all im wanting to do is recive a signal from the computer to turn on a light or more like 16 using a shift registry
« Last Edit: May 26, 2008, 12:48:38 00:48 by Pikoko » Logged
-Given: 562
-Receive: 409
« Reply #1 on: May 26, 2008, 11:10:53 11:10 »
This is quite easy to do, If you have got it in Proton then is shold be easy to port over to PBP
OR even better still i'm sure if read the manual it aslo give an example how to as well
I shall give you some tips how to eran some respect and a better way to get more help
1.Fisrt posting a question without any code or little info to back it up will not get you any where
2. do some research on what it is you want to do
3. have a go at writing your own code then post it here and explain what you can't do
This way you may get a better respone, don't get me wrong we want to help you and welcome new comers but you have give little infromation,
Well that's mt 2 cents worth, Others may view it differently to me
wizpic
Pikoko
« Reply #2 on: May 26, 2008, 09:29:03 21:29 »
okay well thanks for the tip and i had looked threw the manual and the examples in it didnt work .
i ended up getting it working.
INCLUDE "modedefs.bas"
' VARIABLES
Slate VAR byte ' Slate address
Cue  VAR Byte     ' Cue number
' SYMBOLS
Symbol RS232_out = 0 ' RB0 is RS232 output
Symbol RS232_in = 1 ' RB1 is RS232 input
TRISB = 2 ' RB0=output, RB1=input
PAUSE 2000
' Send Heading
Esample:
SERIN RS232_in, T9600, 5000, ESample, #slate
if slate = 255 then goto emode
EMode:
SERIN RS232_in, T9600, 5000, EMode, #cue
     if cue = 0 then emode
         If cue = 1 then cue_1
         if cue = 2 then cue_2
    goto Esample
cue_1:
high portb.7
pause 1000
low portb.7
goto emode
cue_2:
high portb.6
pause 1000
low portb.6
goto emode
now what im wanting to do is add the shiftout command.
iv tried
shiftout portb.7, portb.6, MSBFIRST, 1010\16
pulsout portb.5,1
_____________________________________________
EN = portb.5
EN = 0
shiftout portb.7 portb.6, 2,1010\16
EN = 1
im using a 4 Mhz crystal so would i need to define the OSC as being 4?
« Last Edit: May 26, 2008, 09:33:52 21:33 by Pikoko » Logged
sherm
« Reply #3 on: May 27, 2008, 06:20:41 06:20 »
Here are two good links to get you going. This is a good place to start for any comms based projects from PIC to PC using VB6 and PicBasic Pro.
http://www.rentron.com/sending_data.htm
http://www.rentron.com/receiving_data.htm
Pikoko
« Reply #4 on: May 27, 2008, 06:24:56 06:24 »
EDIT : NO NEED TO START NEW TOPIC FOR THE SAME THING MERGED TOPICS
with a 4MHz crystal can you use the shift out command
so far iv tried
pulsout portb.5,1
EN = portb.5
EN = 0
EN = 1
iv tried defineind the OSC as 4 and 20 and im now stumped and yes i looked threw the manual and did a search on the forums and couldnt find anything that would help.
the project i need this for is a addressable expandable firework firing system and im wanting to use 74hc595's or a6207ea-t which are both latching shift-registries. im using then to keep some i/o on the board free for other things
« Last Edit: May 27, 2008, 06:42:42 06:42 by Wizpic » Logged
