March 13, 2026, 06:02:07 18:02
Author Topic: MikroBasic coding question  (Read 8660 times)
suresh13
« on: May 09, 2006, 11:19:44 11:19 »
Please check this (mikrobasic) code and see if there is any mistakes:
sub procedure led_blink
PORTD.0 = 1
delay_ms(1000)
PORTD.0 = 0
delay_ms(500)
end sub
main:
ADCON1 = %00000111 (makes porta digital)
PORTA = 0                     (clears port a)
TRISA = $FF                   (makes porta as input)
PORTD = 0                     (clear port d)
TRISD = 0                      (port D is output)
dim counter as byte
counter = 0
while 1=1
if porta.0 = 1 then
  counter = counter + 1
end if
if porta.1 = 1 then
  goto next
end if
wend
next:
 'in this part of the program, i need it to loop the sub procedure led_blink with the value of counter. Ex: if counter is 3, then led_blink will execute 3 times. Any ideas guys?
Also, the code:
if porta.0 = 1 then
end if
is too simple i think, cuz i may press the switch once, but maybe there is noise and the pic reads it as 100 presses??? how do i overcome that too???
the switches are pull-down when not pressed and pull-up when pressed.
thanks in advance guys!
hbruno
-Given: 112
-Receive: 75
« Reply #1 on: May 09, 2006, 09:29:34 21:29 »
sub procedure led_blink(dim count as byte)
dim loop as byte
    for loop = 1 to count
       PORTD.0 = 1 delay_ms(1000)
       PORTD.0 = 0 delay_ms(500)
    next loop
end sub
if porta.1 = 1 then led_blink(counter) end if
if porta.0 = 1 then
end if
=> BAD
if Button(PORTA, 0, 10, 1) then inc(counter) end if
=> GOOD
Works with MikroBasic 4.003
Salut.
suresh13
« Reply #2 on: May 10, 2006, 06:37:39 06:37 »
thanks dude!
one more thing though
what if i wanted to display the value of counter in a lcd, how would it be done? my lcd is 16x2, using the 4-bit lcd library.
hbruno
-Given: 112
-Receive: 75
« Reply #3 on: May 10, 2006, 09:49:12 21:49 »
'LCD 4-bit on PORTB
'D7 -> port.7
'D6 -> port.6
'D5 -> port.5
'D4 -> port.4
'E  -> port.3
'RS -> port.2
'R/W -> port.0
  Lcd_Init(PORTB)                        ' Initialize LCD connected to PORTB
  Lcd_Cmd(LCD_CLEAR)               ' Send command to LCD "clear display"
  ByteToStr(Counter, Counter_str) ' Byte -> String[3]
  Lcd_Out(1,4,"Counter")                ' Print txt to LCD, 1st row, 4th column
  Lcd_Out(2,1,Counter_str)            ' Print txt to LCD, 2nd row, 1st column
Salut
suresh13
« Reply #4 on: May 15, 2006, 06:23:13 06:23 »
hi hbruno. the code is working except for one part.
i'm getting an error here.
i put dim counter as byte in the beginning.
LCD display is ok.
counter incrementing is ok also.
just this part.
