May 25, 2025, 07:38:55 19:38
Author Topic: SPI(software based) code or refrenece needed for AT89c51  (Read 4896 times)
tension885
« on: April 06, 2008, 06:44:30 18:44 »
hi,
i need some good reference or sample code for software based SPI
for AT89c51 (only for master side).i have searched but not getting code or reference which show how to implement SPI in software. so please help me with your valuable
suggestions and ideas or experience.
also what is SPI mode 0,0 and 1,1?? how they will be implemented in software?
please do reply  Cry Cry Cry
Epegic
« Reply #1 on: April 09, 2008, 04:03:11 04:03 »
You may try and modify the following code fragment. It was used on drive N3310 phone LCD.
#ifdef SoftSPI
// send one byte (command or data) to display controller
void lcdSendByte(uint8 outByte) {
   uint8 i;
Senable = Low;                  // chip select, active low
for (i=0; i<8; i++) {
   // strip off msb
   if (outByte & 0x80) Sdata = High;
   else Sdata = Low;
   // strobe clock
   Sclock = High;
   Sclock = Low;
   // prepare for next bit
   outByte <<= 1;
Senable = High;
   #endif
