March 13, 2026, 07:36:27 19:36
Author Topic: 3 Phase Sine Generator  (Read 9616 times)
mredbautista
-Given: 31
« on: May 04, 2006, 05:03:42 05:03 »
Dear friends,
I want to generate a 3 phase voltage using PWM or HPWM in PIC16F877. The output of the PIC will be feed to the IGBT with a power supply of 48volts DC. Actually the load motor is 3 phase 48Vac, 1 hp. This is a special motor for old printing machiniries. Basically, it seems that i am building low voltage Variable Frequency Drive (VFD).
I already have the IGBT but the PIC control it seems that it is my bottleneck.
I need some help or suggestion or share on how to construct the PICBASIC code. This is my first time to build 3 phase using PWM/HPWM.
Attach file is the zip-excel file for the 3 phase, I want to build whose output is the same as the graph shown.
More power to all,
mred
If you don’t succeed you are consuming 100% of your ability, try to use 25%.  Cheesy
bajrang
-Given: 245
-Receive: 79
« Reply #1 on: May 04, 2006, 08:17:26 08:17 »
Dear friend,
please check this
http://www.sonsivri.com/forum/showthread.php?t=1054
mredbautista
-Given: 31
« Reply #2 on: May 04, 2006, 09:25:04 09:25 »
Thanks a lot my friend, I have now the idea.
I have some clarification is it possible to use 16F877 to produce 3 phase sine wave?
If anybody have experience, please share...
Warm Regards,
mred
bajrang
-Given: 245
-Receive: 79
« Reply #3 on: May 04, 2006, 10:08:50 10:08 »
Dear friend,
since 16f877 has got only two CCP modules(hardware) it is not possible to generate 3 phase sine wave output, unless you use software for pwm generation that too will be messy.
Best to use 16f777 that has got 3CCP modules.
I have practically realised this circuit. THe problems i faced are:
1)sometimes an erratic peak appears-> probably related to crystal stability ?
2)loss in sine-wave purity-> because of 20 degree resolution in lookup
we can have more discussion.
regards,
bajrang
Yazi
-Receive: 23
« Reply #4 on: May 04, 2006, 12:13:33 12:13 »
hello bajrang, it is very interesting as project can you share with as your work?.
best regards
Kabron
-Given: 71
-Receive: 145
« Reply #5 on: May 04, 2006, 12:42:15 12:42 »
Look @ this thread. I suggest U 2 use MC3PHAC crystall from Freescale (free samples). It's specially designed for AC motors. Also i upload some working design.
http://www.sonsivri.com/forum/showthread.php?t=362&highlight=mc3phac
Yazi
-Receive: 23
« Reply #6 on: May 10, 2006, 07:09:26 19:09 »
hi all,
for the 1 fase sine wave chek this link
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en010947
For the 3 fase i suggest to use the pic 18f2331 who have a materiel interface to drive poer ac motor, better to use dspic 30f2010;)
with regards
sombre
« Reply #7 on: May 16, 2006, 12:49:46 12:49 »
10x by advance
