February 17, 2026, 02:24:48 02:24
Pages: 1 2 [All]
Author Topic: Which AVR programmer for a newbie in AVRs?  (Read 74806 times)
ambo
-Given: 127
« on: February 24, 2008, 07:42:24 07:42 »
Hi,  I'm just an electronics hobbiest and although I have some background in PICs, I'm planning to study AVRs as it seems that most of the good projects always comes out first implemented in AVRs.  Can someone recommend me a good link for a DIY programmer for AVRs.
Thanks in advance.
abbas1707
-Given: 15
-Receive: 25
« Reply #1 on: February 24, 2008, 10:58:49 10:58 »
try pony prog
A Thousand Miles Journey Starts With a Single Step
BaNDiTT
-Given: 6
« Reply #2 on: February 24, 2008, 09:49:16 21:49 »
PonyProg will the right choice Wink
it is really simple n usefull
Follow me, if you can. Life begans @ 3000RPM
Jeckson
-Given: 54
« Reply #3 on: February 25, 2008, 06:38:16 06:38 »
You can used STK200/300 with only 74HCT244 or similiar like:
74HC245(much from old computer boards...)
74HCT541
.etc
Todporn
« Reply #4 on: February 25, 2008, 08:38:32 08:38 »
Hi all,
           I've builded this programmer myself. It's an ISP USB programmer (no need for external powersupply.. just plug-in to the USB port).  It works very well for me.  You maybe interested...  There is one drawback about building this programmer though.  You need to find a way to program (hex code which is downloadable from the website) the ATMEGA8 on the programmer board.
www.rototron.info/?Page=USBAVR/USBAVR.ASPX
kolin
-Given: 28
-Receive: 19
« Reply #5 on: February 25, 2008, 11:23:48 11:23 »
Hello,
I strongly recommends to build USBasp. It's simple, very fast and will be supported in future. Build it on breadboard, it's still simple or if you want to build PCB, choose one of implementation. I've made custom PCB based on http://www.fischl.de/usbasp/usbasp_gr.rar, by adding zener diodes and reset button. I successfully build one (by toner transfer) and it's working like charm. When target chip is running more than about 4MHz, you can use fast SCK. This would shorten programing time under 2s. I attached my version of USBasp board in Eagle, excel sheet with prepared labels to stick to ISP cable, and original firmware and driver package.
rendra
« Reply #6 on: February 27, 2008, 11:14:49 11:14 »
hi  please consider to use AVRPROG as ISP AVR programmer.If using codevision AVR at setting programmer choose Atmel AVRprog(AVR910)
kolin
-Given: 28
-Receive: 19
« Reply #7 on: February 28, 2008, 08:06:08 20:06 »
Hi, AVR910 isn't ideal choice. I have one and when new chip arrives, you have to reprogram firmware of programmer for support of new devices. But new firmware isn't released by atmel. I have problem with this when I accidentally destroyed my AT90S8515. New one was ATmega8515 which was not supported by AVR910. I have to borrow another programmer to update my own. I don't recommend it. And it is slow.
When you need it USB, you have to use converter (FTDI, Prolific...). USBasp is much better. Works perfect also on linux.
Jeckson
-Given: 54
« Reply #8 on: February 29, 2008, 02:37:28 02:37 »
It was needed the AVR MCU
SGordon
« Reply #9 on: March 02, 2008, 05:27:33 05:27 »
Is any programmers  provide in circuit debugger Function's ?
sacoroxo
-Given: 34
-Receive: 26
« Reply #10 on: March 03, 2008, 11:13:01 23:13 »
This site http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Fs-huehn.de%2Felektronik%2Favr-prog%2Favr-prog.htm&lp=de_en&btnTrUrl=Translate describes a very simple Serial / ICSP for AVR to be used with Ponyprog.
Regards.
« Last Edit: April 30, 2008, 04:46:11 16:46 by sacoroxo » Logged
hifni_g
« Reply #11 on: April 30, 2008, 09:48:29 09:48 »
hi ambo,
For the first time i've build ponyprog programmer... very simple programmer and no processor...
Now i am using USBasp programmer  which i build by help ponyprog programmer..
USBasp is AVR device programmer via USB interface, and have more AVR device we can program using this programmer..
Here the file about USBasp
MiCrO-BiT
« Reply #12 on: April 30, 2008, 07:40:12 19:40 »
is stk500
bendjy
« Reply #13 on: April 30, 2008, 08:23:06 20:23 »
I think STK200/300 is good and easy for building.
bendjy
free
-Given: 71
« Reply #14 on: April 30, 2008, 11:02:17 23:02 »
Can USBasp support for ATmega644 ?
« Last Edit: May 01, 2008, 10:55:33 22:55 by free » Logged
Some dream to escape reality, some to change it forever.
- Soichiro Honda -
hifni_g
« Reply #15 on: May 02, 2008, 04:17:13 04:17 »
USBAsp is support ATMega644
belepojegy
« Reply #16 on: May 02, 2008, 07:54:05 07:54 »
HI!
I would recommend USBProg from Embedded Projects. It works fine and you can download many firmwares for it, for example: ISP, OpenOCD debugger, USB to RS232 converter and so on, the only bad thing is with it, that it is relativly expensiv because the ftdi chip. And you have to program a bootloader for the atmega32.
Good luck!
HiDux
« Reply #17 on: May 04, 2008, 07:18:54 07:18 »
http://electroprog.ru/index.php?nma=catalog&fla=stat&cat_id=13&page=1&nums=19
ambo
-Given: 127
« Reply #18 on: May 08, 2008, 01:02:34 13:02 »
Thank you all for your replies.  Now I'm torn between USBASP and USBPROG.  But I think I will build a USBASP first as its much simpler.
samir
-Given: 27
-Receive: 21
« Reply #19 on: May 09, 2008, 05:32:22 05:32 »
AVR JTAG CLONE WOULD BE BETTER CHOICE
http://www.siwawi.arubi.uni-kl.de/avr_projects/evertool/index.html
And compatible with AVR Studio
mylogin
-Receive: 16
« Reply #20 on: May 09, 2008, 04:29:03 16:29 »
We use parallel port AVR programmer, just connector, wire, some resistor, and no other parts, works great and cheap.  works with most of the compilers/tools.  just search the web. (your computer should have a parallel port)
bambo_o
« Reply #21 on: May 16, 2008, 02:11:04 02:11 »
AVR ISP with STK200/300 pinout (connect it to STK200/300 eva board)
http://www.lancos.com/e2p/betterSTK200.gif
Posted on: May 16, 2008, 03:05:05 03:05 - Automerged
I use this USB programmer.
very fast programmer
site: http://www.fischl.de/usbasp/
schematic: http://www.fischl.de/usbasp/bilder/usbasp_circuit.png
ert686868
« Reply #22 on: May 20, 2008, 07:42:09 19:42 »
At89... series good choose, i think
Posted on: May 20, 2008, 08:40:20 20:40 - Automerged
easy prog 5 i used before
Good programmer for promming in circuit design
joprinz
-Given: 10
« Reply #23 on: May 21, 2008, 02:38:51 02:38 »
If you are a beginner then Ponyprog is the easiest to begin with. The serial programmer circuit on the pony programmer website is very easy to make and works pretty well. It supports pretty much all of the widely used AVRs. Its FREE too
www.lancos.com/prog.html
Hope this info is useful!
Good Luck!
LabBoy
« Reply #24 on: May 23, 2008, 12:24:04 12:24 »
You can make hardware and software by yourself.
visit this link --> http://lea.hamradio.si/~s56wix/avrprog/
yikaikai
« Reply #25 on: June 22, 2008, 04:44:07 16:44 »
I found proteus + iccavr can do it
30f4011
-Given: 778
-Receive: 96
« Reply #26 on: July 06, 2008, 01:11:50 13:11 »
Use Atprog (Avr LPT programmer)  , Software :Isp prog.
connections----
                                PC-Parallel-S.                                             Contoller (Side)
                           Reset - Pin 5--------------------------------->RESET
                                Data out - Pin 2--------1Keesistor------------>MOSI
                           Clock - Pin 3-----------1Kres----------------->SCK
                                Data in - Pin 10--------------1kRes----------->MISO
                                Gnd - Pin 18---------------------------------->Gnd
for more details goto http://www.ikalogic.com/isp.php
deveshsamaiya
-Given: 15
« Reply #27 on: May 31, 2010, 08:40:48 20:40 »
three AVR programmers one parallel and two serial port
here is the link...
http://www.electroons.com/tag/avr-programmer/
embedded@iit
pak
-Receive: 17
« Reply #28 on: July 06, 2010, 09:47:52 09:47 »
In my opinion, pony2000 is the best low cost programmer for the entry level and avr dragon is the best choice debugger for the adv level. When avr dragon is used, have a look at this site http://www.aplomb.nl/TechStuff/Dragon/Dragon.html first.
happy mcu programming
pak
pushycat
-Given: 237
-Receive: 1448
« Reply #29 on: July 06, 2010, 04:46:36 16:46 »
For bieginner level and ease, you may also try the USB asp which works on the USB port and too is capable of programming the 89S series with some firmware modifications. www.fischl.de/usbasp
ambo
-Given: 127
« Reply #30 on: May 17, 2011, 03:14:54 15:14 »
Well after 3 years when I initially asked this question, I never really got to build my own h/w programmer.
For one, I already have a universal programmer that supports most avrs (but this is out-circuit programming)  and then I was able to buy a cheap rs232 avrisp version 1.
Then until about 6 months ago, I got hold of a AT89S52 programmer which turns out to be actually an USBASP except that the pins are all wrong such that it wont work on standard avr programming headers.  I had to make an adapter cable to make it work with AVRs.  Guess it uses a modified usbasp f/w.
Until a few weeks ago, I chanced upon the following link while searching google for an avrisp mkii clone.
The USB AVR Lab at http://wiki.ullihome.de/index.php/USBAVR-ISP/de.  Now this h/w programmer I really have to build and actually built.  By changing f/w using the s/w bootloader, it can function as an avrisp mkii, an usbasp, a jatgice mkii,  i2c logger, oscilloscope, usb-ttl.
alberto110
-Given: 50
« Reply #31 on: July 01, 2011, 01:00:54 13:00 »
how can i program atmega8A ( A version  ) . i have stk300 and codevision avr .
thanks
rsync
-Given: 76
-Receive: 20
« Reply #32 on: July 01, 2011, 08:42:35 20:42 »
thanks
You cant . ATMEGA8 can be programmed with parallel port using 10-way ribbon cable connect to avr dragon.
sherazi
« Reply #33 on: January 28, 2013, 11:33:10 11:33 »
USBASP is also a nice one you can use it with avrdude and it wont cost much if you buy a ready made also
dcsmrgun
« Reply #34 on: May 29, 2013, 09:59:09 21:59 »
For $50 you can get the AVR Dragon which will both program and in circuit debug your 8 bit AVR micros.
Unless you're seriously strapped for cash I don't see any reason why any cheaper alternative should be that much more enticing. Plus the ability to step through your code is really nice if you're just learning to program AVR. I wouldn't really recommend anything else, unless you are the sort of person that prefers to build a device yourself. And even then I'd say to just suck it up and spend the fifty Wink
Wuschel
-Given: 25
-Receive: 35
« Reply #35 on: May 30, 2013, 11:07:47 11:07 »
A good low cost USB <-> AVR Programmer is mySmartUSB light
The Programmer can emulate the STK500v2 or AVR910/911 protocol
http://shop.myavr.com/index.php?sp=article.sp.php&artID=200006
-Given: 857
-Receive: 4447
« Reply #36 on: April 07, 2014, 09:52:21 21:52 »
bendjy
Member since 2007 and this (was) is your last post in forum...
little more than a mine is bigger, than your's post.
Old_but_Alive
-Given: 830
-Receive: 122
« Reply #37 on: April 08, 2014, 06:16:40 06:16 »
I would recommend buying a solution which allows you to debug as well as program.
I just noticed amba's post which although in German, is worth investigating.
I personally use the Atmel JTAGICE3 and found it excellent.
I dont like the  JTAGICE MK II as it is not robust, we have blown a few.
micropcb
-Given: 53
-Receive: 390
« Reply #38 on: April 08, 2014, 09:34:47 09:34 »
I have been using the following very cheap programmer/debugger (AVR debugger clone) listed on ebay at
http://www.ebay.com/itm/AVR-USB-Emulator-debugger-programmer-JTAG-ICE-for-Atmel-/160826021353?pt=LH_DefaultDomain_0&hash=item2571fa55e9#ht_2205wt_1344
If someone is working with AVR Studio 4.18 or earlier and the controllers used are amongst the following :
ATMega16, ATmega16L, ATMega162, ATmega162V, ATmega165, ATmega165V, ATMega169, ATmega169V, ATMega32, ATMega323, ATmega323L, ATmega32L, ATMega64, ATmega64L, ATMega128, ATmega128L, AT90CAN128
then this is pretty good for the price.
Best regards.
krishna.velu
-Given: 10
« Reply #39 on: July 23, 2014, 09:36:32 09:36 »
This is not only programmer, This contains AVR-Jtag-ICE 1 debugger also.
http://www.scienceprog.com/avrjtag-clone-in-action
I've made one and Its working seamlessly. The only concern is the supported devices are limited.
Try this.
Marcustv
-Given: 218
-Receive: 15
« Reply #40 on: July 23, 2014, 05:03:39 17:03 »
I bought the programmer USBASP BAITE on the site aliexpress.
It has a really low price.
notes:
The programmer does not work well with firmware BAITE, is necessary change the firmware to Frischi (is very easy to do).  Cheesy
If you want, you can change de type fo the firmware and transform it into a AVRISP mkII mk2 clone.
You can find the AVRISP mkII mk2 clone always for sale on the site Aliexpress sold from huts.
The advantage of the AVRISP mkII mk2 clone is that you can use it directly from the development of WINAVR unlike the USBASP that for it to work it needs an external program.
Marcustv
-Given: 218
-Receive: 15
« Reply #41 on: July 26, 2014, 08:08:44 08:08 »
This is the link of the programmer
http://www.aliexpress.com/item/1LOT-1PCS-USBasp-AVR-Programmer-1PCS-10PIN-65CM-Wire-1PCS-10Pin-TO-6Pin-Adapter-Free-shipping/901230476.html
http://www.aliexpress.com/item/Free-Shipping-USB-programmer-AVRISP-mkII-mk2-clone-ATMEL-AVR-Fit-51-Series-ATmega-PWM-ATtiny/1758679438.html
and these are the link for the firmware to make the change
For change USBASP Baite (no good this firmware) on USBASP compatible you can use:
Frischi firmware http://www.fischl.de/usbasp/
Romolo Firmware http://openrcforums.com/forum/viewtopic.php?f=10&t=1363#p29615  (better)
FUSE
L=FF
H=D9
For transform USBASP on MKII MK2 clone
http://www.projectik.eu/index.php/elektrotechnika/microprocesory/item/download/40_b92f9002c44aa27971ee5392b066ff00
FUSE
atmega8  low  high   EF  C9 = no eesave, no boden, bodlevel 2.7V, 16k+4msec
atmega8  low  high   1F  C1 = si eesave, si boden, bodlevel 4.0V, 16k+0msec
Crackn
-Given: 133
-Receive: 565
« Reply #42 on: October 16, 2014, 06:13:28 06:13 »
FUSE
Fixed Link:
http://www.projectik.eu/index.php/elektrotechnika/microprocesory/item/129-avr-isp-programator-na-usb-ver100
Marcustv
-Given: 218
-Receive: 15
« Reply #43 on: December 08, 2014, 07:19:39 07:19 »
The programmer MKII is managed directly from the development environment AVR Studio, without needing to use external programs required for other types of programmers Grin
naserturk
« Reply #44 on: June 17, 2015, 09:33:34 21:33 »
hello  Smiley
I have USBASP with additional zif socket and its realy help full because it is really fast (up to 5kBytes/sec) and works in multiple  platforms like  windows 8 and 8.1 Linux and Mac OS X.
It is USB and you can use it with your notebook and windows based tablet
and with last firmware that you can find in second link it will support Atmel Tiny Programming Interface (TPI) protocol too
you can build your own version by using this schematic :
and program your programer micro controller chip ( brain of your programmer ) with hex file that
you will find inside this archive file  : http://www.fischl.de/usbasp/usbasp.2011-05-28.tar.gz
and
I recommend this program for using as your programmer interface software :http://khazama.com/project/programmer/KhazamaAVRProgrammer.rar  Cool
with best regards
naserturk
Mega32
-Given: 271
-Receive: 37
« Reply #45 on: June 18, 2015, 04:29:00 16:29 »
This thread was over an year old, don't you think the OP has gotten his prorammer by now ?
Btw: With a cost of less than 2$, and free shppping, i would not concider DIY - i'd just buy one
http://www.ebay.com/itm/201035834899
Mega32
-Given: 857
-Receive: 4447
« Reply #46 on: June 18, 2015, 04:54:51 16:54 »
Mega32
So Funny OP is Muted in line for the purge..
Quote from: ambo link
He was Just A Waste of Space
Martin Miranda
« Reply #47 on: February 15, 2020, 11:31:48 11:31 »
i always suggest to buy the avr ICE. it's a small investment but you'll have the debugging capabilities.
Mr. Spock
-Given: 475
-Receive: 830
« Reply #48 on: February 16, 2020, 12:26:22 00:26 »
Not supported by latest IAR Tools
Martin Miranda
« Reply #49 on: February 17, 2020, 01:39:26 01:39 »
Sad
ouch.
Pages: 1 2 [All]
