March 20, 2026, 10:54:54 10:54
Author Topic: interrupt priority in avr ?  (Read 13067 times)
omidsht
-Given: 60
-Receive: 16
« on: February 03, 2008, 01:11:31 13:11 »
hi ,
how can we set interrupt priority in mega16 ?
for example in 8051 , we had IP register to set up the priority levels , how we do the same in ave mega16 ?
thanks
omid
rtm
-Given: 121
-Receive: 93
a.k.a. klug
« Reply #1 on: February 03, 2008, 06:15:00 18:15 »
Interrupt vectors in atmega16 have fixed priority in accordance with their address. The lower address - the higher priority.
omidsht
-Given: 60
-Receive: 16
« Reply #2 on: February 03, 2008, 08:10:36 20:10 »
are their address fixed or they depend on how you write the program ? i mean can we change their addredd to change the priority ?
omid
rtm
-Given: 121
-Receive: 93
a.k.a. klug
« Reply #3 on: February 03, 2008, 08:22:49 20:22 »
Sorry, I can not reply by PM - it is disabled for me.
Yes, every vector has fixed address. You can not change vector address. For example INT0 interrupt will always change program pointer to $0002 address.
So, you can not change priority of interrupts. The only thing that you can make in your program - to disable other interrupts when starting some interrupt subroutine.
telyadi
« Reply #4 on: February 04, 2008, 10:36:18 10:36 »
a correction:
When an interrupt occurs, the Global Interrupt Enable I-bit is cleared and all interrupts
are disabled. The user software can write logic one to the I-bit to enable nested interrupts.
All enabled interrupts can then interrupt the current interrupt routine. The I-bit is
automatically set again when a – RETI – is executed.
omidsht
-Given: 60
-Receive: 16
« Reply #5 on: February 04, 2008, 04:22:17 16:22 »
a correction:
if I-bit is manually set to one , in interrupt subroutine , does any other interrupt , interrupt the current one or only the one which is higher (the less address) is nested ?
omid
sam_des
-Given: 138
-Receive: 161
« Reply #6 on: February 06, 2008, 08:50:24 08:50 »
Hello omid,
If you enable the interrupts within an ISR, all interrupts irrespective of their priority(address-wise) are enabled. You can check this by simulating in AVRStudio. But AVR docs are unclear about this. So better assume that all interrtups are enabled, if you are going to do nesting.
One way to allow only specific interrupts while nesting is to disable interrupts which are not required just before enabling I-bit. Make sure you re-enable these interrupts before exiting ISR, but after disabling I-bit.
regards,
sam_des
picavr
-Given: 272
-Receive: 101
« Reply #7 on: February 11, 2008, 04:02:56 16:02 »
when you know the chronogramme of evenement you can use this solution
program:
enable interruption-priority1
on intrrupt interruption-priority1 gosub subinterruption1
on intrrupt interruption-priority1 gosub subinterruptionx
do
loop
subinterruption1:
enable interruption-priority2
instruction.....
return
subinterruption2:
enable interruption-priority3
instruction.....
return
subinterruption3:
enable interruption-priority4
instruction.....
return
subinterruptionx
instruction.....
return
mpas
« Reply #8 on: February 24, 2008, 12:16:45 12:16 »
right way is nested interrupt routines don't use
