April 09, 2026, 03:00:20 03:00
Author Topic: can help solve?  (Read 5091 times)
kctan
« on: March 14, 2006, 04:57:09 16:57 »
i using the proton to write this code and i have the problem of the delay time cannot put at the if else statement and i want write the emergency stop button when the button is close (voltage is off) the condition stop when button is open (voltage on) it will resume
Device 16F877A
XTAL = 20 '
crystal 20 Mhz
ALL_DIGITAL
TRUE ' set all input output in digital form
PORTB_PULLUPS = TRUE '
enable the portb have a pullups resistance
Dim i
As Byte
TRISA
= %000000 ' set the port A as ouput
TRISB = %11111111 '
set the port B as output
TRISC
= %00000000 ' set the port C as input
TRISD = %11111111 '
set the port D as input
TRISE
= %000 ' set the port E as input
INTCON = %10010000 '
Enable RB0 interrupt
PORTB
0
ON_INTERRUPT
GoTo emergency
main
Disable
PORTC
= %01100100
If PORTB.6 And PORTB.7 And PORTD.1 1 Then
PORTC
= %00100010 'motor base ccw
EndIf
If PORTD.3 = 1 And PORTB.7 = 1 Then
PORTC = %00001100 '
arm motor clock wise base brake
EndIf
If
PORTD.2 And PORTD.3 1 Then
PORTC
= %10100100 'break base and arm and extrude cylinder
EndIf
If PORTB.5 = 1 And PORTB.7 = 1 And PORTD.3 = 1 Then
PORTC = %10100100 '
Set PORTA.0
'gripper grip
EndIf
If PORTB.1 = 1 And PORTD.3 = 1 Then
PORTC = %10010100 '
gripper grip arm motor up and cylinder in extrude
EndIf
If
PORTD.1 And PORTB.1 And PORTD.3 1 Then
PORTC
= %01100100 'cylinder retract in
EndIf
If PORTB.4 = 1 And PORTD.1 = 1 And PORTB.1 = 1 Then
PORTC = %01100001 '
move left
EndIf
If
PORTB.1 And PORTD.4 And PORTB.4 1 Then
PORTC
= %01001100 ' arm move down, cylinder in retract condition
EndIf
If PORTB.1 =1 And PORTD.4 = 1 And PORTD.2 = 1 Then
PORTC = %10100100 '
arm stop and cylinder extract
EndIf
If
PORTB.5 And PORTD.4 And PORTD.2 1 Then
PORTC
= %10100100 'extrude sensor on and at left and at limit arm up
Clear PORTA.0 '
gripper release
EndIf
If
PORTD.0 And PORTD.2 And PORTD.4 1 Then
PORTC
= %10010100 'arm motor turn ccw and extract valve on
EndIf
If PORTD.1 = 1 And PORTD.4 = 1 And PORTD.0 = 1 Then
PORTC = %01100100 '
motor arm turn off and cylinder retract
EndIf
If
PORTD.1 And PORTB.1 And PORTB.4 1 Then main
emergency
INTCON.7 'disable all interrputs
While PORTB.0 = 0 '
waiting untill
PORTC
= %00100100 ' reset output to PORTC
Wend '
push-button is release
DelayMS 100
' debounce time
' reset RB0 interrupt flag
Context Restore
Resume '
Return to main program
Enable
' Enable interrupts after handler
Sad
