Title: 4x4 keyboard and LCD menu Post by: jesalf on March 31, 2008, 11:17:36 23:17 Hi,
I´m working on a "menu option" with a PIC16F877, LCD and 4x4 keypad, the question, is how can I get a string from the keypad? I know how to get a char but what about a string. Thanks. Title: Re: 4x4 keyboard and LCD menu Post by: Parmin on April 01, 2008, 12:47:01 00:47 Use a buffer and close the string when a "space" character is entered.
Title: Re: 4x4 keyboard and LCD menu Post by: aal on April 04, 2008, 10:05:28 22:05 #include <16F877.h>
#device adc=10 #fuses HS,NOWDT,PROTECT,NOLVP #use delay(clock=20000000) //one instruction=0.2us #use rs232(baud=9600, xmit=PIN_c6, rcv=PIN_c7) #include <lcdtart.c> #define COLON_0 PIN_B0 #define COLON_1 PIN_B1 #define COLON_2 PIN_B2 #define COLON_3 PIN_B3 #define ROW_0 PIN_B4 #define ROW_1 PIN_B5 #define ROW_2 PIN_B6 #define ROW_3 PIN_B7 void colon0() { output_high(COLON_0); //delay_ms(100); if (input(ROW_0)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"7"); printf("7"); } else { if (input(ROW_1)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"8"); } else { if (input(ROW_2)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"9"); } else { if (input(PIN_B7)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"/"); } /*else { lcd_gotoxy( 1, 1); printf(lcd_putc," "); }*/ } } } output_low(COLON_0); } void colon1() { output_high(COLON_1); //delay_ms(100); if (input(ROW_0)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"4"); } else { if (input(ROW_1)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"5"); } else { if (input(ROW_2)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"6"); } else { if (input(PIN_B7)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"X"); } /*else { lcd_gotoxy( 1, 1); printf(lcd_putc," "); }*/ } } } output_low(COLON_1); } void colon2() { output_high(COLON_2); //delay_ms(100); if (input(ROW_0)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"1"); } else { if (input(ROW_1)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"2"); } else { if (input(ROW_2)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"3"); } else { if (input(PIN_B7)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"-"); } /*else { lcd_gotoxy( 1, 1); printf(lcd_putc," "); }*/ } } } output_low(COLON_2); } void colon3() { output_high(COLON_3); //delay_ms(100); if (input(ROW_0)) { lcd_gotoxy( 1, 1); //printf(lcd_putc,"C"); printf(lcd_putc," "); lcd_gotoxy( 1, 1); } else { if (input(ROW_1)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"0"); } else { if (input(ROW_2)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"="); } else { if (input(ROW_3)) { //lcd_gotoxy( 1, 1); printf(lcd_putc,"+"); } /*else { lcd_gotoxy( 1, 1); printf(lcd_putc," "); }*/ } } } output_low(COLON_3); } void main() { lcd_init(); lcd_gotoxy( 1, 1); while(true) { colon0(); colon1(); colon2(); colon3(); delay_ms(200); } } Code: Code: Title: Re: 4x4 keyboard and LCD menu Post by: yavuz on April 07, 2008, 11:52:33 11:52 use a buffer like MyBuffer[20], as you know you can now put 19 characters in this buffer.
if your strings are fixed for example always 5 chars, test if the 6th char is pressed, or use * or # or any other button for entering the string. Don't forget to collect the previous chars in the buffer. for example: Code: char MyBuffer[20],input; // buffer and current key input hope this helps :) Title: Re: 4x4 keyboard and LCD menu Post by: Kloswiski on April 13, 2008, 04:21:20 04:21 CCS C compiler has a rich library and a lot of drivers. One of them deal with keyboard and keypad reading. check picc folder for some examples on this
Title: Re: 4x4 keyboard and LCD menu Post by: niktesla on October 29, 2008, 12:51:40 00:51 @ aal
You could share the lcdtart.c file? niktesla ;) |
