Title: 8051 Hex Code Explorer 1.0 Post by: 94491203 on December 10, 2009, 04:54:45 16:54 This program is written targeting INTEL's 8051 family 8 bit Microcontrollers (64KB of code memory). Limited to '16 bit address' data records. This program will parse and DisAssemble the hex code byte by byte data with addresses. It will show you the complete CODE memory map, the way your object code will reside in the code memory. It will help you to realize the exact picture about how your instruction set will stay physically in the code memory. View Details
http://www.spicelogic.com/Products/ShowDetails.aspx?productID=8051hexExplorer Title: Re: 8051 Hex Code Explorer 1.0 Post by: LEAS on January 03, 2010, 08:17:11 08:17 after installation You must edit 8051hexExplorer.exe.config file to correctly way to files cinstruction_set.mdb uc8051labDB.mdb. Ithink that IDA is right select. Code explorer looks like a toy.
