Title: Details of QED vs Minelab detector - Anyone want to do battle Post by: pickit2 on September 20, 2013, 10:59:18 10:59 Here you will find the build Details for the elusive QED, Deep Seeking Pulse Induction Metal Detector with Active ground balancing. The leaked details included will allow you to build the main control box of the detector which will connect directly to Minelab and compatible coils (as if we need to know were MeTaL is :P)
The QED was a project built to go head to head with Minelabs top of the range machines ($$$) This battle has been going on for so long, it needs an ending, just to *** up the trolls. The designer of the QED stopped working on the machine in early 2013 when Minelab sued him to stop further development of the machine that would have hurt sales their high end gold detectors. Unfortunately, that should have been the end of the QED, but one of the testers helping the designer leaked the code to one of his friends who also wanted to build the machine and thanks to that tester, here we are! So, we present to you the full details of the QED including the hardware PCB files,Schematics, Microcontroller code... Enough for you to build you own machine. Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Magnox on September 20, 2013, 05:05:25 17:05 Ooohh... I'll take a look at that!
A few years ago I was involved in a lot of mostly theoretical talk about the capturing and analysis of pulse induction signals to improve discrimination. It never got much past that stage though and we all moved on. Instead of making my own, I ended up buying a used Fisher F75. After owning it for nearly three years, I finally made my first profit with it... ...by selling it for more than I paid for it! Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Ichan on September 20, 2013, 06:22:37 18:22 I do not know both, but once i ever look closely on a famous gold detector board - what i found is it use high class passive components. I still have my notes on it, have a see, sorry i have to hide most part of the pcb image.
-ichan Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: bobcat1 on September 21, 2013, 02:42:20 14:42 Hi
Instead of arguing on an old technology - use the latest : Ti LDC1000 IC who can be use as a very sensitive metal detector with the add of a micro controller and a display You can detect metal from distance and even distinguish from one another. All the best Bobi Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Checksum8 on September 21, 2013, 05:56:04 17:56 For anyone interested in metal detectors. Geotech forum is great resource. The QED designer Howard aka Bugwhiskers use to post there. You will find many projects and information about metal detectors.
http://www.geotech1.com/forums/forum.php Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: bytraper on September 22, 2013, 12:05:41 12:05 why would you use a Ti LDC1000 IC when you can build a professional detector that blows it away in every regard?
This detector is a modern gold detector with ground balancing supposedly comparable to the latest minelab machines which cost $6500 It can ground balance in the most mineralized ground, if you look at the file from PicKit you can see it has the full schematics, board layouts and micro code! I am going to build this for sure! Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Checksum8 on September 23, 2013, 03:42:56 15:42 For a better understanding of QED operating principles. You can download the QED patent here.
http://ip.com/pat/AU2010101019B4 Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Magnox on May 04, 2014, 01:36:39 01:36 Since the original link is dead, here it is again. Thanks to Pickit for it.
Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: bytraper on May 10, 2014, 12:35:17 12:35 If you plan on going to Australia to do some detecting, do yourself a fasvour and build this detector. Buy a good used Coiltek, nuggetfinder ot Minelab coil from eBay and start building!
There's a lot of people doing mods on this schematic on geotech and other forums that are well worth checking out. Compared to the $6500 Minelab machines, this has the capacity to be so much better. There's enough information in the file to build one from scratch! Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Ichan on June 19, 2014, 05:50:42 17:50 Does this QED really works?
I did some search and found mixed opinion, one said this one as vapourware (?) Any other good discriminating pulse induction detector around? (I hasn't yet register on the geotech forum) -ichan Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: bytraper on July 04, 2014, 05:03:42 05:03 It works... everything you need to build it is in the files. The reason it was called vapourware is because there was lots of rumours of its existence, but nothing that was ever publicly released for it and that's because minelab sued the inventor to stop any further progress on it.
Its a good detector, up there with the best you can buy for gold in mineralized ground! Everything you need to build it is in the files! Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Ichan on July 08, 2014, 09:49:32 21:49 Than you for the confirmation.
How is the performance, great? What coil do you use? Any link to a DIY coil for this? -ichan Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Magnox on July 09, 2014, 04:30:46 16:30 I made a coil myself once, for the Practical Electroncis Magnum (I think) - unless you really enjoy it and have much better mechanical skills than me (quite possible) I would suggest buying one. If the Magnum would work with a commercial coil it might do better than it does with my DIY one.
I'm really curious about the QED too. I recall the arguments surrounding it years ago. If cash (or rather its lack) weren't such a problem now I would be very tempted to have a board made and build one of these. Always wanted to try a really good PI machine. There are people working on alternatives based on the QED on other forums, but nothing is available yet from what I've seen. Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: bytraper on February 10, 2015, 12:51:29 00:51 The problem is that nobody will release designs they've done. Its a machine that is more than capable and I know of 1 unit that's been built but I don't know how it performed.
Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Tekno1 on February 24, 2015, 08:38:50 08:38 Hello,
This subject lokks interesting! Link of plans.txt file of Magnox is dead. Any new link. Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Magnox on February 24, 2015, 10:31:00 10:31 Here you go
Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: zac on April 30, 2016, 06:23:36 18:23 Could some some please post the link again? Thanks.
This overview of pulse induction technology might be interesting: http://renesasrulz.com/design_contest_archives/the_rx_mcu_design_contest/f/78/t/3586.aspx Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: andybiker on June 12, 2018, 09:22:27 09:22 Does anyone still have these files?
(I have just become interested in metal detecting) Thanks. Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Rute on June 15, 2018, 06:16:40 18:16 Hi,
I'm interested in this source too, Please! help! :) Best, Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Magnox on June 15, 2018, 07:31:18 19:31 Here you are...
Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: fpgaguy on June 19, 2018, 06:26:30 18:26 Anyone want me to convert this to Altium or Allegro with a real BOM ?
I need a spare time project Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: Unhappy on June 20, 2018, 07:12:50 19:12 Anyone want me to convert this to Altium or Allegro with a real BOM ? I need a spare time project Why not? if you can in Altium TIA Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: fpgaguy on November 07, 2018, 05:08:31 17:08 Couple opinions wanted before I pick parts -
The code looks ok and builds, the schematic couple issues - 1) there is an analog spst x 4 switch with no part #, perhaps it is ADG5212 ? what do you think ? 2) there is also TI LME49990, which is no longer made - I was thinking OPA1611 as replacement 3) now for sense coil there are a lot of variations here with a lot of magic, since this is PI and two coil (TX + RX) connector is made, perhaps the choices can be narrowed down. As much as I like playing with litz wire I'm tempted to buy off the shelf from different unit 4) dsp looks like 33FJ128MC804 5) LCD looks like 3 digits * 7 segment, 2 x DP and a COM, GND, and 3.3V maybe something like lumex lcd-s301c31tf but with backlight Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: DreamCat on August 28, 2020, 04:30:22 04:30 anyone have source file yet ?
I want to play with this . Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: koky on August 28, 2020, 07:23:14 07:23 see file
Title: Re: Details of QED vs Minelab detector - Anyone want to do battle Post by: wtrk on January 17, 2021, 08:41:34 08:41 Did someone make this detector ?
