Title: Smartphone Elektor application RGB control Vs esp8266 Post by: gianmagna on February 25, 2021, 03:11:22 15:11 In this project I have reused an ELEKTOR APP. Elektor December 2016
The original design used an atmel328p and an ESP-01 module as hardware. I used an ESP-01 module in combination with a PIC 16f1827and with the AT commands I adjusted the outputs of the RGB PWM and the OUT pins as in the project that I present. The difference lies in the ESP module and in the use of a much more interesting software. I used a Wemos D1 Mini a 74hc595, uln2803 driver and a mosfet for RGB outputs; you can also delete the 74hc595 and use all the bits directly on the module esp. Other port expansion circuits can also be used, in I2C (Ex: PCF8574) or in SPI (Ex: CD4094) and more. So I simplified the hardware of the first project. basic esp code: '****************************************************************************** ' Programma di controlo RGB e 8 OUT con APP WIFI CONTROL ' estratto della rivista Elektor Dicembre 2016 ' che utilizzava ATMEL328P e MODULO ESP-01 ' ' Programma per moduli ESP12-E ESP12-F ' link App di Elektor ' https://play.google.com/store/apps/details?id=com.elektor.wificontrol ' link esp basic ' https://sites.google.com/site/annexwifi/home ' link esp basic help ' https://cicciocb.com/annexhelp/V1.42//?topic= ' ' Date : 3/05/2020 ' Autori gianmagna & son '++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ D0=16:D1=5:D2=4:D3=0:D4=2:D5=14:D6=12:D7=13:D8=15:D9=3:D10=1 x = 0 Dim abc$(80) pin.mode 16,Output 'CS per SPI spi.setup 100000 onUrlMessage urlAjax Wait urlAjax: wlog "message received " + UrlMsgGet$() 'message received example ':80/?m1=&P1=1&P2=1&P3=1&P4=1&P5=1&P6=1&P7=1&P8=1&s=&Rv=84&Gv=173&Bv=86 (all OUT 1 + rgb) 'message received ':80/?m1=&s=&Rv=84&Gv=173&Bv=86 (all OUT 0 + RGB) abc$ = UrlMsgGet$() 'lettura messaggio 'catturo il valore se 0 o 1 P1 = val(UrlMsgGet$("P1")) P2 = val(UrlMsgGet$("P2")) P3 = val(UrlMsgGet$("P3")) P4 = val(UrlMsgGet$("P4")) P5 = val(UrlMsgGet$("P5")) P6 = val(UrlMsgGet$("P6")) P7 = val(UrlMsgGet$("P7")) P8 = val(UrlMsgGet$("P8")) 'catturo il valore di R G B r = val(UrlMsgGet$("Rv")) v = val(UrlMsgGet$("Gv")) b = val(UrlMsgGet$("Bv")) wlog p1, p2 ,p3, p4, p5, p6, p7, p8 ' visualizzo i pin wlog r, v, b ' visualizzo R G B 'sul Modulo 12-F e' possibile usare questi pin direttamente sulle uscite X = 0 'P1 TO P8 representano lo stato di ogni pin If P1 = 1 Then X = X Or 1 If P2 = 1 Then X = X Or 2 If P3 = 1 Then X = X Or 4 If P4 = 1 Then X = X Or 8 If P5 = 1 Then X = X Or 16 If P6 = 1 Then X = X Or 32 If P7 = 1 Then X = X Or 64 If P8 = 1 Then X = X Or 128 wlog X ' valore del byte con i pin attivi ' qui e' possibile usare SPI con 74hc595 e I2C PCF8574 pin(16) = 0 ' CS LOW pin 14 del 74hc595 X = spi.Byte(X) pin(16) = 1 ' CS High carico il latch del 74hc595 pin(16) = 0 ' CS Low 74hc595 'pwm values are 0 to 1023, but R,G,B values are only 0 to 255, so need multiplying by 4 to match PWM(12) = r * 4 PWM(15) = v * 4 PWM(2) = b * 4 URLMSGRETURN "ok" Return End '************************************************************************ The application can be downloaded from this link: https://play.google.com/store/apps/details?id=Com.elektor.wificontrol Once installed, the APP only requires the IP address of the receiver and automatically puts the door: 80 In our case we have to add the IP address + "/ msg?" And that's it! For example: (192.168.1.35/msg?) Then select the bits you want to turn on and the color sliders Press SEND photo https://ibb.co/bd7Xr2m (https://ibb.co/bd7Xr2m) https://ibb.co/JxqyQbt (https://ibb.co/JxqyQbt) https://ibb.co/VCg3rgK (https://ibb.co/VCg3rgK) https://ibb.co/kSzYjXB (https://ibb.co/kSzYjXB) available for explanations Gianmagna |
