Title: Question: PICBasic Pro how to receive more than 2 byte of data from PC Post by: rod27cn on May 11, 2008, 05:59:24 17:59 Hello, Can somebody help me on how to received more than 2 bytes of data from PC using PICBasic Pro. I am using PIC16F876A.
Please advise some idea or examples. Thanks! :) Posted on: May 11, 2008, 06:57:52 18:57 - Automerged I am using RS232 communication by the way, I forgot to mention it. Title: Re: Question: PICBasic Pro how to receive more than 2 byte of data from PC Post by: strat on May 11, 2008, 08:19:09 20:19 You can use arrays. But the program worked on the PC must send data to Pic by byte variable.
Title: Re: Question: PICBasic Pro how to receive more than 2 byte of data from PC Post by: maddoc on May 12, 2008, 08:47:22 08:47 I use a loop in the main program to receive nonstop data.
It usually can process around 19200bps of info with those CASE statements full of code. I use to receive data also in the CASE statements, because some commands need 1 to 50 bytes of data. Code:
