Title: Wireless RS232[ideas] Post by: Wizpic on January 26, 2019, 12:07:42 00:07 I have a PCB that gives serial data and a program that runs on a laptop where I can view all the settings and alter the setting at the moment it use's the cable.
My Idea would it be possible to make this wireless either buying ready made units but which type or even better still design and make my own if possible. On searching I found some but then they start talking about Bluetooth or one way commination I need both ways as the software does an handshake. Any suggestions links and ideas would be great Title: Re: Wireless RS232[ideas] Post by: Old_but_Alive on January 26, 2019, 07:46:26 07:46 my first thought was Buetooth HC-05 modules, very cheap, and easy to use.
However, no hardware hanshaking ( DTR/CTS etc) same with the newer DT-06 wifi to serial. You dont say whether the handshaking is hardware or software (Xon/Xoff) If its the latter both should work fine. If its really hardware flow control, I fear you will have to do it alone. That may be achievable using an ESP8266 module and bespoke software. Title: Re: Wireless RS232[ideas] Post by: PICker on January 26, 2019, 12:39:16 12:39 There are some 433 MHz alternative RF modules like, for example, the ones at the following links:
https://www.tindie.com/products/lensentech/smart-rf-module-433mhz-data-transceiver-ttl/ https://www.tindie.com/products/lensentech/100mw-rf-module-433mhz-rs232-rs485-ttl-to-wireless/ Unfortunatly they dont have hardware handshaking. A more complex (and expensive) module with CTS/RTS signals is this one: http://www.farnell.com/datasheets/56734.pdf Title: Re: Wireless RS232[ideas] Post by: Wizpic on January 26, 2019, 09:41:43 21:41 Sorry Guy's I should of mentioned, The Serial data comes from some software called webgpi by a company called Danfloss, I've not yet tried to look at the signals and only assume that it does handshake when the unit is not turned on it reports unit not responding. On the controller pcb there is a micro controller with a serial port which gives out the data where you can alter the setting and use it as a tool for fault finding. I cannot get any information on what data or how it sends it through the serial port.
I just thought rather than using a long serial cable see about making it wireless, I did think about trying the HC-05 modules as the baud rate is 11500, but at a guess I would have to use a logic converter as those modules work 0n 3.3V Title: Re: Wireless RS232[ideas] Post by: especialista on January 26, 2019, 10:04:09 22:04 I've made a data aquisition system in the past based on cheap ZigBee modules. It worths a look!
Title: Re: Wireless RS232[ideas] Post by: PICker on January 26, 2019, 10:44:54 22:44 Wizpic,
from WebGPI datasheet I've found on this site (hxxps://prom-electric.ru/media/WebGPI.pdf) seems that two serial cables are available (pag. 48): 1) Sauer-Danfoss Cable PN 1090740 (3 wires?) for the Sauer-Danfoss Microcontrollers MC200/MC400 2) Sauer-Danfoss Cable PN KW02027 or PN KW02012 (6 wires) for the Sauer-Danfoss Microcontrollers MC300/S2X If the cable uses only 3 wires (TX-RX-GND) it is possible that there is a proprietary connection protocol between Sauer-Danfoss software and the microcontroller; in this case it will be no so difficult to implement a wireless connection by a small circuit with two rs232 level translators (ie max232 )and two wireless tranceiver modules (FULL DUPLEX?). Please check how many cables are used in serial transmission, for example by building a custom serial cable (with only 3 wires) for the connection between PC and the microcontroller unit. If the used serial signals are more than TX-RX-(GND), the implementation of the wireless transmission will be more tricky. Title: Re: Wireless RS232[ideas] Post by: Wizpic on January 28, 2019, 12:11:20 12:11 I will look into that and check it out when I get the board home so that I can start playing. At the moment it just uses a standard 9 wire serial cable, Hope fully it just uses 3 wires like another tester we use for a different machines/manufacture so I know that one could be done using 3 wires
Posted on: January 26, 2019, 06:52:03 18:52 - Automerged I’m in luck, I’ve tested the controller and it just used 3 wire connection, so I guess that I can use the HC-05 Bluetooth modules with a logic converter has the system runs 5v supply Or are there better devices ? Title: Re: Wireless RS232[ideas] Post by: PICker on January 28, 2019, 08:42:33 20:42 Wizpic,
it is possible to make the HC-05-Module compatible with 5V signals with some hardware mods and a lot of patience: https://www.instructables.com/id/Make-Bluetooth-HC-05-Module-5v-Compatable/ There are other solutions like: https://www.openimpulse.com/blog/products-page/product-category/4-0-bluetooth-module-3-3v-5v-comptabile/ https://tenacious33.wordpress.com/2012/07/21/5v-tolerant-bluetooth-module/ https://it.aliexpress.com/item/Wireless-Bluetooth-Module-Serial-Transceiver-Compatible-with-3-3V-5V-for-Arduino-RPi-AVR/32350474249.html (I do not know if the core remains the cheap HC-05-Module with some workaround circuit) Title: Re: Wireless RS232[ideas] Post by: sadman on January 30, 2019, 05:16:03 05:16 why doing tedious modification to the HC Bluetooth module simple solution is to use level converter Bi directional from SparkFun which do the job better i used it with WiFi module for same task.
https://www.sparkfun.com/products/12009 Title: Re: Wireless RS232[ideas] Post by: Wizpic on March 06, 2019, 08:04:28 20:04 I've got some HC-05 in, Got them paired and set up,All ok
The trouble I'm facing it does not work as expected, Just for testing I've just used and Arduino mega to read pot value and send out the data on the serial one port at 38400 baud on the master also sending the data out on the normal serial port, This looks ok. On the salve side I've tired 2 ways first was connecting my RS232 usb to serial port converter and connected the input's to it and started an serial monitor but getting rubbish through like this Code: €ø€ø€ø€€ø€øøøøøøøøø€€ø€€€øø€øøøø Code: €ø€ø€ø€€ø€øøøøøøøøø€€ø€€€øø€øøøø Code: 76 May be I'm looking at this wrong, I can't really use another Arduino on the RX side as this will not communicate with the software that runs on the laptop, I've checked all the settings and baud rates they all match any ideas or is this what you get without using a second Arduino. The set up I'm looking for is no Arduino's (only used to check it) Is the HC-05 one as master connected to board that give the RS232 on the machine then this signal gets transmit and the other HC-05 set as slave to the software on laptop UPDATE:I double checked the baud rates and the defaults should of been 38400 on the HC-05's but when checked they where set to 9600, sSo I've changed them but still not getting the numbers I was expecting. This is what I get now Code: OQR;TTT;Q=O@LEJIJLC@>Q;TT8TR=IILE>QTTROFI Title: Re: Wireless RS232[ideas] Post by: kreutz on March 06, 2019, 08:38:17 20:38 You are probably receiving data and treating it as ASCII characters, you need to convert the (binary) data received into hex or bcd as needed
Title: Re: Wireless RS232[ideas] Post by: Parmin on March 06, 2019, 10:26:59 22:26 +1 to what Kreutz say.
The data conversion is not sync properly. Another thing to do is to reduce the baud rate until you have a good transmission. Title: Re: Wireless RS232[ideas] Post by: Wizpic on March 07, 2019, 06:39:04 06:39 I've tried connecting these modules direct to the PCB and laptop where I want them to work and they did not work, So guess it's back to the drawing board and re-think.
Parmin, kreutz I know what you mean but I really can't use any micro I just wanted to make an RS232 @ 115200 baud to a wireless bridge between the two units. Think I will just have to bite the bullet and buy one Title: Re: Wireless RS232[ideas] Post by: kreutz on March 07, 2019, 02:09:39 14:09 You don't need to change the micro. Review your serial receiving code and change it to convert the received data bytes to BCD and then convert BCD to string, check exactly what you are transmitting using a terminal program on a PC. I will look around for an example, but it will take me some time...
See: http://www.fiz-ix.com/2012/11/arduino-serial-communication-bytes-bases-and-ascii-characters/ (http://www.fiz-ix.com/2012/11/arduino-serial-communication-bytes-bases-and-ascii-characters/) Title: Re: Wireless RS232[ideas] Post by: Wizpic on March 07, 2019, 04:23:40 16:23 I have done a bit more searching and I'm think the HC-05 works on TTL signals so I need an Max232 on both side which I've ordered some of E-bay, I seen a on a link which I will put on here later when I get home
Title: Re: Wireless RS232[ideas] Post by: kreutz on March 07, 2019, 06:32:07 18:32 Arduino inputs/outputs are ttl signals..
Title: Re: Wireless RS232[ideas] Post by: Wizpic on March 07, 2019, 09:07:18 21:07 I don't really want to use any micro controller at all I just want a straight wireless RS232 bridge between the PCB below and laptop which runs the software, I'm not sure if this PCB gives TTL signals as it just uses 3 wire serial cable. I was only trying the Arduino way jsut to make sure that the modules where working in sending data beofre I connected/tried on the real set-up, But I have tried it and it does not connect the PCB, This is why I thoguht I'd try MAX232 in-between the HC-05
Here is the link for that web page where they make the wireless RS232 unit https://eksfiles.net/a-build-it-yourself-bluetooth-serial-interface/ (https://eksfiles.net/a-build-it-yourself-bluetooth-serial-interface/) This is why I thought of the Max232 chips. I've attached some pics of the PCB and software to show you what I'm trying to make. The PCB. My trail setup was one arduino connected to the master jsut reading a Pot and sending that value to the HC-05 for TX and the RX I just used an FTL232 converter and connected to the slave HO-05, But I only get rubish as I posted above, I will try it with 2 arduinos for TX&RX which I know will work or I can get it to as it should, This is not as easy has I thought but hey I love a chalange. Title: Re: Wireless RS232[ideas] Post by: kreutz on March 07, 2019, 09:26:58 21:26 Your linked article is about connecting the HC-05 to a PC using RS232 or two PCs using two HC-05 modules, in case of two Arduinos (instead of PCs) you should be connecting each Arduino's TTL output and input (TX and Rx Respectively) to the HC-05's RX and Tx pins respectively (level translation in between is also necessary), so there is no need to the Max232 chips in between.
If you are receiving data (even if not the one you expected) means that there is communication between them (HC-05s). If the serial configuration for both, Arduinos and HC-05, is the same (baudrate, #of bits, parity, Stop bits), they your data being displayed in ASCII mode is due either to your Received byte processing or your Transmitted byte processing code, or both of them. Posting your code would help us to help you find the cause. In case of your pcb and laptop you will need the RS232 chip between the PCb (or Laptop) and the HC-05 (as well as the level translation between the max232 and the HC-05 because the MAX232 needs 5Vdc Vcc and HC-05 i/o levels are 3.3. volts maximum) Title: Re: Wireless RS232[ideas] Post by: Wizpic on March 07, 2019, 09:37:35 21:37 I see this is where I got the confusion from.
This is the TX side(crude but only for a simple test) on a Arduino Mega Code: int potValue = 0; This is the RX side(again crude but quick test), Bearing in mind I've not tired this version yet, As I thought that I could just use the FTL232 converter to read the data from the HC-05 then display it on PC. Code: #define led 9 Title: Re: Wireless RS232[ideas] Post by: kreutz on March 07, 2019, 10:04:41 22:04 I guess you didn't read carefully the link I posted above:
" To give you an example, if you were to send the letter A to an Arduino via serial and saved the incoming byte as myByte using code like that given above, the numerical decimal value of myByte would be 65. Try the following code and enter A in the serial terminal and you will notice that the number 65 is returned to the terminal and output to the screen because the Serial.print() function by default prints the decimal value of the byte. byte myByte; void setup(void){ Serial.begin(9600); // begin serial communication } void loop(void) { if (Serial.available()>0) { // there are bytes in the serial buffer to read while(Serial.available()>0) { // every time a byte is read it is expunged // from the serial buffer so keep reading the buffer until all the bytes // have been read. myByte = Serial.read(); // read in the next byte } Serial.println(myByte); // print byte to screen delay(100); // a short delay } } If you want to instead print the ASCII character corresponding to myByte, use the Serial.write() function instead. You can also use an additional argument to tell the Serial.print() function to display the byte using the decimal, hexadecimal, octadecimal, or binary base numeral systems. The following code will take a byte read in from the serial terminal and print it to the terminal using these various bases. byte myByte; void setup(void){ Serial.begin(9600); // begin serial communication } void loop(void) { if (Serial.available()>0) { // there are bytes in the serial buffer to read while(Serial.available()>0) { // every time a byte is read it is expunged // from the serial buffer so keep reading the buffer until all the bytes // have been read. myByte = Serial.read(); // read in the next byte } Serial.println(myByte, DEC); // base 10, this is the default Serial.println(myByte, HEX); // base 16 Serial.println(myByte, OCT); // base 8 Serial.println(myByte, BIN); // base 2 Serial.write(myByte); // ASCII character Serial.println(); // carriage return delay(100); // a short delay } } (all of the above was copied and pasted here from my linked article) " Posted on: March 07, 2019, 03:49:17 15:49 - Automerged Basically: Using Serial.println() you can specify what format data is being sent. Using Serial.write() you always send ASCII. Posted on: March 07, 2019, 03:53:43 15:53 - Automerged How your terminal software, in your laptop, displays the data is also important. Posted on: March 07, 2019, 03:55:13 15:55 - Automerged Read also how to configure the serial interface here: https://www.arduino.cc/reference/en/language/functions/communication/serial/begin/ Title: Re: Wireless RS232[ideas] Post by: Wizpic on March 07, 2019, 11:02:50 23:02 Sorry I had a quick skim through it, But will read it in depth, As I said before the Arduino is only for testing the linkage between the 2 HC-05 modules. I did change the serial.write to Serial.print and got more or less same rubbish in the serial terminal software. once I read through the link you mentioned I will test the software and see about getting it working that way just for fun but by connecting the HC-05 to PCB and laptop I thought this should work as is as all the coding is done for that already.
I just thought becasue the PCB and laptop commitcate trough the serial port via a cable(which is already been pre set by the supplier) that these HC-05 modules would just repalce the cable and send the same data via bluetooth, But the slight down fall is the range but should be ok as I'm nenver more than 5/10 feet away from the machine. I know that if you try and make your own serial commications you have to think about missing bits or ending the transmission and all about timing but that has already been taken care of by the supplier. May be I've been looking at this all the wrong way Title: Re: Wireless RS232[ideas] Post by: wacks on March 08, 2019, 03:10:00 03:10 From my understanding you also need to set the correct baud rate to use on those HC-05 modules.
[Arduino 1/Serial Device 1] <==> [HC-05] ~~~~~ [HC-05] <==> [Arduino 2/Serial Device 2] If you change the baud rate of Serial Device 1 and Serial Device 2 it will no longer match the baud rate of those HC-05 modules, hence you will see garbage data. From the illustration below the data is already corrupted when the data has entered the first HC-05 module. [Arduino 1/ Serial Device 1 @34800] <==> [HC-05 @ 9600] ~~~~~ [HC-05 @ 9600] <==> [Arduino 2/Serial Device 2 @ 34800] The correct one is to use the same baud rate for all devices: [Arduino 1/ Serial Device 1 @34800] <==> [HC-05 @ 34800] ~~~~~ [HC-05 @ 34800] <==> [Arduino 2/Serial Device 2 @ 34800] To change the baud rate of HC-05 modules: Connect the module's KEY pin (pin 34) to 3.3V Use a terminal (adjust the baud rate to match the default 9600 of the module unless the module's baud rate has been changed before) AT+UART? tell you the default baud rate. If you receive no response then the baud rate did not match the module AT+UART=9600 set the baud rate to 9600. AT+RESET reset and save changes. Also note that some HC-05 modules (with breakout board) are rated 5V since the 3.3V voltage regulator and level translator are already incorporated on the breakout board. Just my 2cents. |
