Title: RC5 code Post by: nileshhande on May 06, 2008, 11:22:57 11:22 hi all,
want to control few relays via infrared remote control: some latch,some momentry and some timer based..and 1 port PWM if possible thanks... Title: Re: RC5 code Post by: mississippi1 on May 06, 2008, 04:22:40 16:22 That should be no problem with a PIC16F628a.
PBP is than also the right language for this problem. Title: Re: RC5 code Post by: nileshhande on May 07, 2008, 07:38:44 07:38 Thanks..can i have the project detals.(schematic and code)
thanks a lot. Title: Re: RC5 code Post by: maddoc on May 07, 2008, 08:39:59 08:39 Here is an extract from Proton IDE, basic compiler, found on this forum.
You just have to put next to the PIC an IR receiver like rpm71xx or tsop48xx (xx stands for IR frequency, go for 40 with RC5 codes). Code: RC5IN 12 14 16 Title: Re: RC5 code Post by: DINESHjp on August 23, 2008, 02:14:46 02:14 i think rc5in is not a valid command in proton ide
Title: Re: RC5 code Post by: pickit2 on August 23, 2008, 07:49:24 19:49 i think rc5in is not a valid command in proton ide Yes it is----------------------------from the Help file------------ RC5IN Syntax Variable = RC5IN Overview Receive Philips RC5 infrared data from a predetermined pin. The pin is automatically made an input. Operators Variable - a bit, byte, word, dword, or float variable, that will be loaded by RC5In. The return data from the RC5In command consists of two bytes, the SYSTEM byte containing the type of remote used. i.e. TV, Video etc, and the COMMAND byte containing the actual button value. The order of the bytes is COMMAND (low byte) then SYSTEM (high byte). If a byte variable is used to receive data from the infrared sensor then only the COMMAND byte will be received. Example Device = 16F877 RC5IN_PIN = PORTC.0 ' Choose the port and pin for the infrared sensor DIM RC5_WORD as WORD ' Create a WORD variable to receive the data DIM RC5_COMMAND as RC5_WORD.Lowbyte ' Alias the COMMAND byte to RC5_WORD low byte DIM RC5_SYSTEM as RC5_WORD.Highbyte ' Alias the COMMAND byte to RC5_WORD high byte ALL_DIGITAL = ON ' Make all pins digital mode Cls ' Clear the LCD While 1 = 1 ' Create an infinite loop Repeat RC5_WORD = RC5In ' Receive a signal from the infrared sensor Until RC5_COMMAND<> 255 ' Keep looking until a valid header found Print at 1,1,"SYSTEM ",Dec RC5_SYSTEM," " ' Display the SYSTEM value Print at 2,1,"COMMAND ",Dec RC5_COMMAND," " ' Display the COMMAND value Wend Declares There is a single Declare for use with RC5In: - DECLARE RC5IN_PIN PORT . PIN Assigns the Port and Pin that will be used to input infrared data by the RC5In command. This may be any valid port on the PICmicro. If the Declare is not used in the program, then the default Port and Pin is PORTB.0. Notes The RC5In command will return with both COMMAND and SYSTEM bytes containing 255 if a valid header was not received. The CARRY (STATUS.0) flag will also be set if an invalid header was received. This is an ideal method of determining if the signal received is of the correct type. RC5In is oscillator independent as long as the crystal frequency is declared at the top of the program. If no XTAL Declare is used, then RC5In defaults to a 4MHz crystal frequency for its timing. See Also SONYIN Title: Re: RC5 code Post by: DINESHjp on August 24, 2008, 01:05:41 01:05 i once again search the command rc5in in help also but it is not available
i am using proton+basic compiler downloaded from this forum. ide version 1.0.0.1 and compiler version 2.2.0.20 Title: Re: RC5 code Post by: pickit2 on August 24, 2008, 11:12:00 11:12 Your way out of date with Proton IDE
ide current ver 1.0.4.6 compiler current version is 3.2.5.5 Title: Re: RC5 code Post by: DINESHjp on August 25, 2008, 12:55:15 00:55 where can i download this version , there are so many version that i am confused, so plz help me
Title: Re: RC5 code Post by: Ahmad_k on August 25, 2008, 04:22:45 16:22 Take this :
Proton IDE 1.0.4.6 and Compiler 3.2.5.5 http://www.sonsivri.com/forum/index.php?topic=4267.msg21417#msg21417 Title: Re: RC5 code Post by: ABBOSE on October 15, 2008, 03:12:27 15:12 Hi nileshhande
for infrared remote control see http://amateurworld.in/sd_4/3%20channel%20IR%20remote%20control.html Title: Re: RC5 code Post by: nileshhande on October 16, 2008, 04:45:55 16:45 HI, Thanks..Good explanation, Source code is in Assly, Basic code would have helped a lot..Thanks lot..
