Title: ARM Parallel Port Programmer Problem not detecting the target?? Post by: xpress_embedo on January 28, 2014, 05:10:09 05:10 Helllo!!! Everyone i am using this Parallel Port Programmer
http://shop.ngxtechnologies.com/prod...products_id=29 to program my LPC2148, it is a Wiggler Based Programmer and is supported by H-JTAG Software. I tried to use this programmer with Keil Directly, but failed because i had not started H-JTAG Server, after that i started H-JTAG Server and my Controller gets detected as ARM7TDMI-S microcontroller in H-JTAG Server, after that i open H-Flasher and then program a simple code to blink LED's. Its programs and verify properly but LED's on board doesn't work but when i reset the board by reinserting its power it works. But after that H-JTAG Server is not able to detect the target, i dont know why?? Its works for the first time and till now it is not detecting target and giving this error. (http://www.edaboard.com/attachments/101576d1390874972-error.png) Even if i didn't connect the hardware its giving the same error. Please suggest me what might be the problem. |
