Title: CCS C 4.xxx Post by: chenyi.com on August 25, 2010, 01:29:38 13:29 http://www.4shared.com/get/pqqRBBIX/CCS_PCWHD_4110_update.html
Title: Re: CCS C PCWHD 4.110 Post by: Old_but_Alive on August 25, 2010, 02:18:08 14:18 v4.110, and 4.111 seem to be buggy http://www.ccsinfo.com/forum/viewtopic.php?t=43333 probably better wait for v4.112 Title: Re: CCS C PCWHD 4.110 Post by: xzb on September 06, 2010, 04:05:48 04:05 the pic18f6520 bug,no Microcontroller Mode config.
Title: Re: CCS C PCWHD 4.110 Post by: ALLPIC on September 17, 2010, 06:02:26 06:02 Can some one tell me which is really good version of CCS
Title: Re: CCS C PCWHD 4.110 Post by: sysypet on October 19, 2010, 01:45:01 01:45 CCS 4.106 is stable and good working.
Title: Re: CCS C PCWHD 4.114 Post by: Old_but_Alive on November 04, 2010, 01:26:56 13:26 anyone got PCWHD v4.114 ?
Title: Re: CCS C PCWHD 4.110 Post by: Rey Mafia on November 05, 2010, 08:00:14 20:00 Does anybody know whether the USB library supports 18f14k50 and 18f13k50?
Title: Re: CCS C PCWHD 4.114 Post by: godblessu on December 09, 2010, 01:23:42 13:23 Here is PCWHD 4.114 update.
http://www.4shared.com/file/l1ZEIjms/CCS_PCWHD_4114.html and if you need a keygen see http://www.sonsivri.com/forum/index.php?topic=28473.msg98264#msg98264 Enjoy. Title: Re: CCS C PCWHD 4.110 Post by: Raflex on December 09, 2010, 03:02:34 15:02 Does anybody know whether the USB library supports 18f14k50 and 18f13k50? The USB library supports 18f14k50 without issues. Title: CCS C PCWHD 4.115 Post by: Old_but_Alive on December 14, 2010, 09:03:38 09:03 here we go again !!
********** A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 4.115 Recent changes include: 4.115 PCD SPI defines SPI_XMIT... have been modified to operate the same as PCM and PCH 4.115 A number of device database errors have been fixed 4.115 A PIC24 bug with &= on 32 bit operands is fixed 4.115 New #USE TIMER library added ********** Title: Re: CCS C PCWHD 4.115 Post by: jaikumar on December 14, 2010, 09:28:03 09:28 The problem with CCS is that the updates are not just for new parts or newer performance.
There are always fixes from bad coding. WHEN WILL THEY EVER HAVE A STABLE PRODUCT? regards, Jai. Title: Re: CCS C PCWHD 4.110 Post by: metal on December 14, 2010, 11:04:03 11:04 Thanks to you, guys, you test this stuff for them :)
Title: Re: CCS C PCWHD 4.110 Post by: chronus on December 16, 2010, 02:56:13 02:56 and now 4.116!!
"A corrupt device database released with 4.115 is fixed" and they actually charge people for this product, amazing. Title: Re: CCS C PCWHD 4.110 Post by: gan_canny on December 16, 2010, 03:55:52 15:55 CCS has issues but so do most compilers. Others release versions once or twice per year if that and fix many bugs that go unnoticed unless you are one of those stymied by a bug. How many bugs did Microsoft fix with Win7? It was never disclosed. CCS fixes rapidly and you have the choice of staying with an earlier version ( the best of both worlds). Sure everyone knows CCS fixed things so some will see that as a negative. CCS is as good or better a compiler as any. Microchip device updates are frequent interfaces to hardware is efficient with the many built in functions code is compact.
Title: Re: CCS C PCWHD 4.110 Post by: jaikumar on December 17, 2010, 09:30:35 09:30 gan_canny has a good point.
regards, jai. Title: Re: CCS C PCWHD 4.110 Post by: metal on December 17, 2010, 10:46:00 10:46 Good point on one side of fixing the bugs quickly, but still, these symptoms imply a bad active team.
You can't compare to windows, can you? The size of windows Project is very large, and you come to compare it to a small compiler? Built-in libs makes the compiler a nice tool to work with, but when frequent updates are flooded this way, users will no longer feel safe using it. Title: Re: CCS C PCWHD 4.110 Post by: Old_but_Alive on December 17, 2010, 10:55:59 10:55 the real problem is they dont test updates before they release them.
Also they don't itemise the bug fixes in detail, so its hard to know whether a bug you have has been fixed. the main problem is with the PCD for 16 bit devices. its a kludge, not written from scratch, so it really is a dodgy compiler for PIC24 and DsPIC. Title: Re: CCS C PCWHD 4.110 Post by: semaphore on December 18, 2010, 03:37:41 03:37 Here is PCWHD 4.114 update. http://www.4shared.com/file/l1ZEIjms/CCS_PCWHD_4114.html and if you need a keygen see http://www.sonsivri.com/forum/index.php?topic=28473.msg98264#msg98264 Enjoy. The Keygen doesn't work for me. It said the PCD is invalid. The rest are fine. Any help would be appreciated! Title: Re: CCS C PCWHD 4.110 Post by: pissant on January 22, 2011, 12:58:34 00:58 The Keygen doesn't work for me. It said the PCD is invalid. The rest are fine. Any help would be appreciated! Just tested that link. Works fine here with the PCD compiler (as well as the others). Try generating the license files again. Title: Re: CCS C PCWHD 4.110 Post by: mayler on January 23, 2011, 11:01:08 23:01 Just tested that link. Works fine here with the PCD compiler (as well as the others). Try generating the license files again. The license files are working for me normally too. Title: Re: CCS C PCWHD 4.110 Post by: pissant on January 28, 2011, 11:32:43 11:32 Don't use 4.114 if you are using pic18 chips and using the built in set_timer2() command. It will drive you insane.... the compiler programs the wrong register and the timer never runs. You end up having to do it all manually. Once you start programming registers manually, you might as well just use the C18 compiler from Microchip.
How the **** could they screw up one of their basic old old old commands??? :o The CCS compiler is a mess. Title: Re: CCS C PCWHD 4.110 Post by: gan_canny on January 28, 2011, 02:58:04 14:58 for.................... set_timer2(0);
the CCS 4114 compiler generates 00118: CLRF FCC where FCC is the address of the TMR2 register I don't see the issue, Ive never had the issue and if it did exist its just one line of code to fix. Now timer2 is an 8 bit timer so if set via a variable the variable needs to be 8 bits or cast to 8 bits There are some minor issues ( Microchip issues) with 16 bit timers and interrupts. With 8 bit registers it takes two operations to set a 16 bit counter. An interrupt could possibly occur between the two operations. It is standard good coding practice to disable interrupts when posting to 16bit or more variables that are used within interrupt service routines.This practice avoids the rare possibility that a half updated value is used in an isr. Title: Re: CCS C PCWHD 4.110 Post by: pissant on February 01, 2011, 01:59:51 01:59 for.................... set_timer2(0); the CCS 4114 compiler generates 00118: CLRF FCC where FCC is the address of the TMR2 register I don't see the issue, Ive never had the issue and if it did exist its just one line of code to fix. Sorry, I meant to type setup_timer2(), not set_timer2. Whoops! See this post on the CCS forums: http://ccsinfo.com/forum/viewtopic.php?t=44166&highlight=114 Same problem with the ccp2 setup... see this post (from PCM Programmer, about halfway down): http://ccsinfo.com/forum/viewtopic.php?t=44564&highlight=setuptimer2 Of course its possible to set those registers manually. Might as well just use C18 in that case though. I've used CCS in the past for banging together quick test code. Not any more I guess. I actually had a full paid for version up until around 4.080 or so but finally gave up. The 24/30/33 compiler remained a piece of crap even after all those revisions and I was having to use C30 anyhow, so I gave up and quit renewing year after year. I still have a tiny hope that they'll sort it all out one day and I'll be able to come back, but its likely a lost cause at this point. Title: Re: CCS C PCWHD 4.110 Post by: mcr on February 08, 2011, 07:10:06 19:10 Yep, CCS has a lot of bugs but it does free you from writting your own functions.
I had those PICs (18F45k22 and 46k22) and tested them with no luck, until I found PCM Programer: http://ccsinfo.com/forum/viewtopic.php?t=43961&highlight=pic18f45k22 http://ccsinfo.com/forum/viewtopic.php?t=43829&highlight=pic18f45k22 Title: Re: CCS C PCWHD 4.110 Post by: mario2000 on March 01, 2011, 05:26:57 17:26 ccs 4.114 LCD.C, Does not work or I can not work >:( , please i need a help. Title: Re: CCS C PCWHD 4.110 Post by: gan_canny on March 01, 2011, 05:41:34 17:41 Well there are many types of LCD and many ways they can have issues.
First you need to know whether your LCD has a controller. If it doesn't have a controller this will be a very difficult project for you. Is the LCD character or graphic or both. Is it a serial interface ( rs232 I2C SPI) or parallel If parallel is it a 4 bit or 8 bit interface. Does it have the correct bias voltage to provide contrast. When all that is known next comes the initialization an initial command is often sent then a delay before sending additional commands. LCD.C is a template rather than a universal solution. Title: Re: CCS C PCWHD 4.110 Post by: mario2000 on March 01, 2011, 10:03:15 22:03 Hi, thanks for replying, the problem is that the new version of the code lcd.c changed, now lcd.c no works
This is a sample code: Code: #include <16F873A.h> I downloaded the compiler from the following link provided on this site: http://www.4shared.com/file/l1ZEIjms/CCS_PCWHD_4114.html upload simulation here. Title: Re: CCS C PCWHD 4.110 Post by: gan_canny on March 26, 2011, 02:39:14 14:39 There isn't enough information to help you. The code snippet suggests a 4 bit parallel interface to a LCD controller.
The printf(lcd_putc,"Helo World"); is a recursive call . This is a feature of CCS in that they take each character from the string starting with "H" and call lcd_putc. It is called several times until the string is fully read. Now lcdputc in turn has to break the char into two nibbles and call the LCD interface for each nibble. It also has to not exceed any LCD timing issues. Simulation is helpful but often leads to the expectation that what is artificial can become real. The real PCB circuit and components will if you are lucky behave as simulated. The more complex the project the more the risk that it won't. Title: Re: CCS C PCWHD 4.110 Post by: kemalserkan on March 29, 2011, 06:28:25 06:28 there is a problem in lcd.c library. i'm using 18f4550. i want to use portd for lcd. i can use lcd with my own lcd library, but i cant use portd pins with lcd.c. i disable the spp module, but still it doesnt work. here is the pin connection(i'm using ccsc 4.114)
#include <lcd.c> #define ENABLE_PIN D3 #define RS_PIN D2 #define RW_PIN D0 #define Data4 D4 #define Data5 D5 #define Data6 D6 #define Data7 D7 Title: Re: CCS C PCWHD 4.110 Post by: gan_canny on March 29, 2011, 01:46:03 13:46 Well again you aren't disclosing the error messages you get just that it doesn't work with lcd.c
You may know this but in case you don't #defines are like the replace function in a word processor. The compiler jut replaces the expression on the left with the expression on the right so #define Data4 D4 means Data4 is replaced with D4 but now that means D4 also needs to be defined. Typically it would be #define D4 PIN_D4 and PIN_D4 in turn is redefined by the compiler to be a numbered pin where the number is specific to the pic chip ( this part is automatic after you specify the device( chip) so you don't need to define PIN_D4). Title: Re: CCS C PCWHD 4.110 Post by: mitsos on June 14, 2011, 03:49:29 15:49 hi
for all the good people here, pcwhd v4.120 http://www.4shared.com/file/6uvS-Xnx/CCS4120.html regards mitsos Title: Re: CCS C PCWHD 4.110 Post by: machine on July 12, 2011, 01:50:39 01:50 The files not contain keygen...
Title: Re: CCS C PCWHD 4.110 Post by: glitch_inc on July 12, 2011, 03:30:20 03:30 Its in this thread on the first page. Post by GodBlessU
Title: Re: CCS C PCWHD 4.110 Post by: petarp on July 13, 2011, 08:46:34 08:46 Hi. Anyone have CCS ver. 4.121 and 4.122?
Please share. Thanks. Title: Re: CCS C PCWHD 4.110 Post by: cjack on September 23, 2011, 06:31:52 06:31 Hi all! Version 4.124 it's here:
http://www.fileserve.com/file/pCxUgM5 IdeUtils here: http://www.fileserve.com/file/fdhfDag Enjoy :D Title: Re: CCS C PCWHD 4.110 Post by: mitsos on September 24, 2011, 06:26:08 18:26 hi
something goes wrong with fileserve as free user. I download(many times) the pc4124.exe with size 1.31MBytes instead of 22.51Mbytes. Can someone reupload both files to ifile.it for example. regards mitsos Title: Re: CCS C PCWHD 4.110 Post by: tuane06 on October 04, 2011, 03:51:18 15:51 Hi,i am lucky when downloaded it,so i uploaded to mediafire and share it for you,goodluck
http://www.mediafire.com/?av2bsf9q35q9cor Title: Re: CCS C PCWHD 4.110 Post by: adriatec on January 14, 2012, 01:16:14 13:16 Hi, as far as I know the new series of dsPIC33E and PIC24E supported by the version 4.128 of the CCS PCWHD. If anybody has, please share with us.
Title: CCS PCWHD v4.128 Post by: ulderico on January 28, 2012, 08:00:50 08:00 http://ifile.it/egp9836
:D Enjoy! Title: Re: CCS C 4.xxx Post by: metal on January 28, 2012, 08:42:02 08:42 This thread is now for CCS C v4.xxx
Title: Re: CCS C 4.xxx Post by: Old_but_Alive on January 28, 2012, 06:35:34 18:35 @ulderico, the link is already bad Title: Re: CCS C 4.xxx Post by: Wannabe on January 28, 2012, 07:07:24 19:07 http://www.mediafire.com/?3snvlvr0z6fq9na
Title: Re: CCS C 4.xxx Post by: alichan on January 30, 2012, 08:39:12 20:39 Just a suggestion.
Could you do as in the thread for Labcenter Proteus, centralizing all the important links in an untouchable main post in this same thread? So we could follow the changes easily without polluting the thread with comments. Something like: Date: Dec 20, 1980 CCS 4.100: link (keygen not provided) Keygen: link Cheers Title: Re: CCS C 4.xxx Post by: fonak on March 11, 2012, 02:09:04 14:09 Hi all sonsivri's.
Anyone have new version ccs compiler 4,130 ? Please shere. Recent changes. 4.130 The setup_low_volt_detect() function missing for many parts is back 4.130 Poor optimization of CONST data structure access is fixed 4.130 A bug declaring variables inside a for statement is fixed 4.130 A hex file problem when using both #FILL_ROM and #ROM is fixed 4.130 I2C slave functions and EX_SLAVE have been updated to work with the newest chips 4.129 Support for the newest devices has been added 4.129 Built in functions for the EPMP module have been added 4.129 Some issues with the PIC24 EP chips have been resolved 4.129 Added a work-around for the UART problem on KA3xx parts 4.128 A typecast inconsistancy with ANSI for 24 bit parts is fixed 4.128 A device database problem with EP chips is fixed Title: Re: CCS C 4.xxx Post by: diamadiss on March 23, 2012, 08:08:34 20:08 Hello,
I install CCS v4.128 and MPLAB®IDE Plug-in. I run the ccs and i make build in my code and works ok. When i try to make build via mplab shows me a message "registration file error' in picture below. Also i install version CCS v4.108 and shows me the same message. I have windows 7 ultimate 64-bit. Thanks. Title: Re: CCS C 4.xxx Post by: TheOwlar on March 28, 2012, 06:47:30 18:47 You may know this but in case you don't... MPLAB comes with a free version of the CSS
In the picture, it would seem that you are using the free version and not the "FULL" one Title: Re: CCS C 4.xxx Post by: ulderico on March 31, 2012, 09:48:18 09:48 PCWHD v4.130
http://www.4shared.com/zip/6i9w_nzm/PCWHDv4130.html :D Enjoy! Title: Re: CCS C 4.xxx Post by: eljose on March 31, 2012, 10:55:14 10:55 Can you upload it on another server please, i don't have a 4shared account, and i can't download it.
Thanks Title: Re: CCS C 4.xxx Post by: lucasdark on April 01, 2012, 12:09:31 00:09 You can Subscribe free of charge.
Best regards, Saludos, Title: Re: CCS C 4.xxx Post by: pickit2 on April 01, 2012, 12:29:39 00:29 English Keygen
http://rapidshare.com/files/380332174/SCG-PCWHD-keygen.rar Title: Re: CCS C 4.xxx Post by: jaikumar on April 02, 2012, 07:44:29 07:44 Hi all,
Even as we are downloading the 4.130 version, CCS has done it again: CURRENT SOFTWARE VERSIONS Version 4.131 RECENT CHANGES 4.131 A problem with cerrors on calls to some overloaded functions is fixed 4.131 The PCD #ASM CLR and SETM instructions now work again 4.131 #HEXCOMMENT now works with multiple compilation units 4.131 A bug whrn #FILL_ROM and #ROM are both used is now fixed Regards, Jai. Title: Re: CCS C 4.xxx Post by: TheOwlar on April 06, 2012, 04:08:03 16:08 Hello,
Believe it or not... CCS has a new version RECENT CHANGES 4.132 A problem with FIXED_IO on port C for some chips is fixed 4.132 A problem with function arguments with multi-dimention arrays is fixed 4.132 Some fuse names have been corrected BTW: Can someone reupload 4.130 Best regards, Saludos... Title: Re: CCS C 4.xxx Post by: joshua1 on April 06, 2012, 04:44:05 16:44 http://www.4shared.com/zip/6i9w_nzm/PCWHDv4130.html
deleted file please upload it again Title: Re: CCS C 4.xxx Post by: gan_canny on April 06, 2012, 04:58:30 16:58 Some compiler vendors update every 6 months leaving customers long periods in which workarounds are the only solution. Others like CCS have a compiler that can have several versions installed simultaneously on a single PC. CCS has a stable version and the latest version with the weekly or daily fixes. If there is an issue that the latest version fixes then there is no need for a workaround if there is no issue then the stable version suffices.
If the issue isn't fixed in the latest version then the next version may address it. Some never having experienced the necessity of using workarounds for months on end aren't understanding the value of a rapid versioning approach. If rapid versioning is a problem then only using the CCS stable version and waiting several months for the next one is always available as a choice. Title: Re: CCS C 4.xxx Post by: juliozv on April 06, 2012, 05:06:25 17:06 CCS 4.130
open with NoteBlock, the archive is .rtf of MAC OSX Title: Re: CCS C 4.xxx Post by: lovefool on April 26, 2012, 01:43:17 13:43 4.130 Windows
For those use torrent to download files. Title: Re: CCS C 4.xxx Post by: mesex69 on May 09, 2012, 02:02:58 14:02 http://www.4shared.com/get/8ZApZ1wj/PCWHDv4130.html
Title: Re: CCS C 4.xxx Post by: engvidal on July 20, 2012, 04:52:12 16:52 CCS 4.120 is out of bugs
Title: Re: CCS C 4.xxx Post by: ulderico on July 20, 2012, 07:47:19 19:47 http://www.4shared.com/rar/pRavQFII/pcwhdv4134.html
Enjoy! Title: Re: CCS C 4.xxx Post by: MGLSOFT on October 14, 2012, 01:21:19 01:21 Here !! ;D ;D ;D
v4.137 Edit: Use text files to upload links into posts. Title: Re: CCS C 4.xxx Post by: gamegurus on November 19, 2012, 11:42:44 11:42 They have release 4.138 with new ICs support. Anyone able to provide it for download?
Title: Re: CCS C 4.xxx Post by: Armageddon on November 19, 2012, 04:18:50 16:18 I hope that the relase 4.138 completely support the PIC32, to test it. Greetings for all.
Title: Re: CCS C 4.xxx Post by: TA5CT on November 19, 2012, 07:16:32 19:16 http://s2.dosya.tc/server21/grFBuC/pcwhd_4.138.zip.html
Enjoy! Title: Re: CCS C 4.xxx Post by: kreutz on December 01, 2012, 05:43:44 17:43 Upgrade to version 4.140 is already out...
Improvements: 4.140 An access violation when using bit_ functions is fixed 4.139 A problem relocating the int vector to high memory on the ENH16 parts is fixed 4.139 A compiler error when using a variable pin for some ENH16 ports is fixed 4.139 A syntax error with void functions as pointers is fixed 4.139 Some packed structure problems have been fixed Title: Re: CCS C 4.xxx Post by: Xyloid on December 28, 2012, 03:12:10 15:12 Hello, it looks like there is a pretty nasty bug in 4.138 with respect to making pointers to functions. Previously the code always compiled, now it does not.
Does anyone have the 4.140 version? Happy New Years! Title: Re: CCS C 4.xxx Post by: ulderico on December 30, 2012, 07:31:42 19:31 OK!
Happy new year! Enjoy! Title: Re: CCS C 4.xxx Post by: Xyloid on January 01, 2013, 05:16:41 05:16 Thank you for the upgrade to 4.140!!! My home automation code now compiles as it should with pointers to functions ;D What a great way to start the new year!!!
Title: Re: CCS C 4.xxx Post by: aliveli on January 29, 2013, 01:41:31 01:41 i am taking "Exception EAccessViolation in module" error with this v4.140
anyone elsetaking this? and do you know any solution? Title: Re: CCS C 4.xxx Post by: mayler on February 02, 2013, 11:19:20 11:19 I compiled several projects with 4.140 and they are ok. Try uninstalling and making a clean install.
I'm using Windows 7 x64 home premium. Title: Re: CCS C 4.xxx Post by: Brosske on February 08, 2013, 08:23:38 20:23 Hi all,
rar unavailable... can someone re-upload please ? thanks & greetz :-) Title: Re: CCS C 4.xxx Post by: ehnonymouse on February 09, 2013, 03:42:21 15:42 Re-upload of 4.140. I've not tried this before, so I hope it works.
Title: Re: CCS C 4.xxx Post by: alichan on February 16, 2013, 05:20:22 17:20 CCS 4.140 (keygen included)
Updated link: 16-02-2013 http://depositfiles.com/files/006sqktjl (http://depositfiles.com/files/006sqktjl) password: sonsivri Title: Re: CCS C 4.xxx Post by: mitsos on June 27, 2013, 01:00:12 13:00 hi
the last update of version 4, is the 140? regards mitsos Title: Re: CCS C 4.xxx Post by: tomywong on June 27, 2013, 01:58:39 13:58 No, it is v4.141. You can see someone ask question about v4.141 here : http://www.ccsinfo.com/forum/viewtopic.php?p=172815
Title: Re: CCS C 4.xxx Post by: Rute on June 27, 2013, 10:21:13 22:21 nop,
the latest version is 5.005d! Best, Title: Re: CCS C 4.xxx Post by: hock on June 28, 2013, 01:29:55 13:29 can some one please upload the latest version. i am having issues with ver 4.140 on PIC18f24k22. the serial com is not working.
Hock Title: Re: CCS C 4.xxx Post by: sphinx on July 08, 2013, 05:37:50 05:37 here is what i found on the net while searching version 4.141 i have installed it and it reports itself as 141 but i have not compiled anything on it due to my preference in assembler
Title: Re: CCS C 4.xxx Post by: pickit2 on October 29, 2020, 02:50:23 14:50 http://www.4shared.com/zip/6i9w_nzm/PCWHDv4130.html 15 years a member and so little use to being a member of any forum. deleted file please upload it again |
