Title: Rhinocam pluggin for rhino 4 Post by: cncdude on August 12, 2010, 12:46:12 00:46 RhinoCAM PRO 2.0.4.0 | 75MB RhinoCAM is a Rhinoceros plug-in that runs completely inside of Rhino. This plug-in is a general purpose machining program targeted at the general machinist. RhinoCAM includes 2-1/2, 3, 4 & 5 axis milling and hole making operations. It comes with hundreds of post-processors and additionally a post-processor generator to create user definable post-processors. The table below summarizes the various features found in each of the available configurations of RhinoCAM 2.0. NOTE: RhinoCAM 2.0 is a plug-in that is completely integrated in Rhinoceros 4.0* and requires Rhinoceros 4.0 to be installed in order for it to run. It is not a standalone application. Also note that RhinoCAM 2.0 does not include Rhinoceros 4.0. It will have to be purchased separately. *Rhinoceros 4.0 is a NURBS based 3D CAD modeler that can be used to create, edit, analyze, document, render, animate, and translate NURBS* curves, surfaces, and solids and polygon meshes. It supports the following file translators: DWG/DXF(AutoCAD 200x, 14, 13, and 12 ), IGES, SAT (ACIS), DGN, FBX, X_T (Parasolid), 3DS, LWO, STL, SLC, OBJ, AI, RIB, POV, UDO, VRML, BMP, TGA, CSV (export properties and hydrostatics), uncompressed TIFF, STEP, VDA, GHS, GTS, KML, PLY, SketchUP, SolidWorks. For more information on Rhinoceros 4.0 go to Modeling tools for designers 2-1/2 Axis Milling STD Pocketing Profiling Facing Engraving V-Carving V-Carve Roughing Chamfering Hole Making Thread Milling Re-Machining 3 Axis Milling Horizontal Roughing Parallel Finishing Horizontal Finishing Radial Machining Spiral Machining Plunge Roughing Horizontal Re-roughing Plunge Re-roughing Projection Pocketing 3D Offset Profiling 3D Offset Pocketing Pencil Tracing Valley Re-Machining Plateau Machining Steep Area Parallel Machining Horizontal Hill Machining Curve Machining Between 2 Curves Machining Reverse Post Machining 4 Axis Milling 4 Axis Indexed Machining 4 Axis Auto Multiple Indexing 4 Axis Continuous Facing 4 Axis Continuous Pocketing 4 Axis Continuous Profiling 4 Axis Continuous Engraving 4 Axis Continuous Finishing 4 Axis Continuous Roughing 5 Axis Milling 4 Axis Indexed Machining Hole Making Automatic Hole Selection, Sorting Drilling Tapping Boring Reverse Boring User Defined Cycles 4 Axis Drilling 4 Axis Tapping 4 Axis Boring 4 Axis Reverse Boring Toolpath Simulation Toolpath Animation Cut Material Simulation Advanced Cut Material Simulation Standard Mill Tools (Ball, Flat, Corner Radius, V, Taper) Standard Drill Tools (Drill, Tap, Bore, Reverse Bore) Form Tools Holder Collision Detection Toolpath Graphical Editing Toolpath Instancing Toolpath Arc Fitting Customizable Post Generator Simulate Cycles Arc Output Helix Output Spiral Output 5 Axis Output (Extra Cost) HTML Based Shop Documentation Knowledge Base Fixture Offset Programming Check Surface Boundary Creation Tool Silhouette Boundary Creation Tool Double Contact Boundary Creation Tool Holder Collision Boundary Creation G-Code Editor & Analysis Tool DNC for single port http://hotfile.com/dl/39588989/4be5799/RhinoCAM_PRO_v2.0.4.0___.rar. ps if anyone has rhino 4 for me as a rapidshare id appreciate it,i did have it on my old pc but can not get into it . Title: Re: Rhinocam pluggin for rhino 4 Post by: solutions on August 12, 2010, 01:10:16 01:10 ps if anyone has rhino 4 for me as a rapidshare id appreciate it,i did have it on my old pc but can not get into it . I haven't tried these out, but the links are good: http://rapidshare.com/files/334980529/Rhino.4.0.SR7.2009.12.14.part1.rar http://rapidshare.com/files/334980738/Rhino.4.0.SR7.2009.12.14.part2.rar http://rapidshare.com/files/334982403/Rhino.4.0.SR7.2009.12.14.part3.rar http://rapidshare.com/files/334980756/Rhino.4.0.SR7.2009.12.14.part4.rar Title: Re: Rhinocam pluggin for rhino 4 Post by: cncdude on August 12, 2010, 01:43:14 01:43 cheers ive just this minute found 3, downloaded them,gone to extract but prompted for password ???if i cant get in i,ll try those;)
Title: Re: Rhinocam pluggin for rhino 4 Post by: cncdude on August 13, 2010, 01:22:49 13:22 just to add the 4 files for the above rhino 4 are an evaluation version,which will only let you save 25 times, there is a text document within the files with several serial keys but i never got an option to use them have i missed something? is it possible to unlock the evaluation package?
Title: Re: Rhinocam pluggin for rhino 4 Post by: Amon on August 22, 2012, 12:50:40 12:50 RhinoCAM link is dead.
Another option? Thank you. |
