Title: Rhinoceros All Versions Post by: rodos2006 on June 11, 2008, 08:56:41 08:56 NURBS MODELING
To be an effective designer today, you need tools to quickly develop your designs and accurately communicate them to everyone in the product research, development, marketing, and manufacturing or construction process. Start with a sketch, drawing, physical model, scan data, or only an idea�Rhino provides the tools to accurately model and document your designs ready for rendering, animation, drafting, engineering, analysis, and manufacturing or construction. Rhino can create, edit, analyze, document, render, animate, and translate NURBS curves, surfaces, and solids with no limits on complexity, degree, or size. Rhino also supports polygon meshes and point clouds. Rhino offers: Uninhibited free-form 3-D modeling. Tools like those found only in products costing 20 to 50 times more. Accurately model any shape you can imagine. Extreme precision. Design, prototype, engineer, analyze, document, and manufacture anything of any size no matter how small or how large. Unrestricted editing. Revise freely without concern about how you got there or where you want to go next. 2-D drafting, annotation, and illustration. In addition, flatten 3-D surfaces into 2-D patterns and drive laser, plasma, and water jet cutters. Large project organization. Work with both large models and large teams. Compatibility. Exchange files with your other design, drafting, CAM, engineering, analysis, rendering, animation, and illustration software. File read and repair. Fix extremely challenging IGES and mesh files. Direct connection. Support for wide variety of 3-D digitizing arms, 3-D scanners, and 3-D printers. Customization. Easy-to-use tools let both you and software developers make Rhino fit your special needs. Short learning curve. Focus on design and visualization without being distracted by the software. Speed. Even on an ordinary laptop computer Rhino is fast. No special hardware is required. Affordability. Ordinary hardware. Short learning curve. Priced like other Windows software. No maintenance fees. Worldwide support is included. Download: Pass: www.tsbay.org CODE http://rapidshare.com/files/101205082/www.tsbay.org_Rino.part1.rar http://rapidshare.com/files/101259254/www.tsbay.org_Rino.part2.rar EDIT: All LINKS WORKING as of 13/08/2010 Title: Re: Rhinoceros All Versions Post by: cncdude on August 15, 2010, 02:39:28 14:39 aye mick i,ll have a go at those i was on this most of last night lol, finally managed to get the top two links installed and running.
it turns out its not the links but the way i was trying to extract them.. i kept getting missing cab file errors on extraction..then someone suggested i save to desktop then extract them instead of ... there fine although rhinocam and v ray say the version of rhino4 is too old for them so mick your links will come in usefull. Title: Re: Rhinoceros All Versions Post by: magico on September 02, 2012, 06:22:41 18:22 Hello,
I need a newer version, can someone help me? The links are dead. Thanks <=== NOTE: The mark of a Leech ===<<< Title: Re: Rhinoceros All Versions Post by: optikon on September 02, 2012, 07:45:13 19:45 You need a newer version?
such as? Rhino 3D v5.0 Beta (Full Functional) 8-30-2012 build *** Rhino 4.0 SR5 or newer must be installed for Rhino 5.0 to work. http://download.rhino3d.com/rhino/5.0/beta/changes/ Not tested by me. Report back results please. See attached Title: Re: Rhinoceros All Versions Post by: sfiga69 on January 17, 2013, 10:57:04 10:57 New version of RhinoCam
rhinocam.premium.2012.(v3,0,0,56) Posted on: October 22, 2012, 03:06:50 15:06 - Automerged Rhinoceros (32bit) 5.1.20927.2230 For info: http://www.rhino3d.com/new (http://www.rhino3d.com/new) Tested on XP sp3 Work fine. Edit: link updated with Rhinoceros (64bit) 5.1.20927.2230 (not tested) Edit 1: attached file corrected Title: Re: Rhinoceros All Versions Post by: solutions on January 17, 2013, 07:40:42 19:40 Anyone know if RhinoCAM works with 5.1?
Title: Re: Rhinoceros All Versions Post by: sfiga69 on January 17, 2013, 08:42:08 20:42 Yesssss
with rhinocam.premium.2012.(v3,0,0,56) of my previous post, it work. I installed this version of Rhino 4 SR9 RhinoCAM, then I installed rhino 5 (Win Xp 32b). When you open rhino5, RhinoCAM is loaded and it seems to work properly. Title: Re: Rhinoceros All Versions Post by: mick on January 23, 2013, 04:13:54 16:13 Try google
Rhinoceros 5.1.20927.2230 Title: Re: Rhinoceros All Versions Post by: sfiga69 on January 24, 2013, 08:17:45 20:17 correct link in my original post
Title: Re: Rhinoceros All Versions Post by: gmua on August 14, 2013, 07:37:46 19:37 link updated with Rhinoceros (64bit) 5.1.20927.2230 (not tested) I've been using the 64 bit version for two weeks now, and not a single glitch. (Thanks sfiga69) The provided installer is just missing the template files, the training material and the updated help files. LanguagePack_en-us.msi HelpMedia.msi After installing both MSI files open Rhino and type ToolbarReset (in the Command line) close Rhino and reopen. This will delete the scheme in the registry, and reopening will reset it with the missing components. Enjoy... Title: RhinoCAM 2012 for Rhino 5.0 (32 Bit) Post by: gmua on August 14, 2013, 09:09:07 21:09 MecSoft Corporation | RhinoCAM 2012 Product Version 3.0.0.59 | (Apr 2, 2013) | [76,150 Kb]
RhinoCAM is a Rhinoceros plug-in that runs completely inside of Rhino 4.0 & 5.0. Combining the free-form modeling power of Rhino and the legendary machining capabilities of VisualMILL, this plug-in offers an easy to use yet powerful general purpose machining program for the general machinist. RhinoCAM includes 2-1/2, 3, 4 & 5 axis milling and hole making operations. It comes with hundreds of free post-processors as well as a post-processor generator to create user definable post-processors. NOTE: RhinoCAM 2012 for Rhino 5.0 requires the Rhinoceros 5.0 CAD system to be installed. If you have not installed Rhinoceros 5.0 please install that first before installing RhinoCAM 2012. After installing, replace the original RhinoCAM 2012V5.rhp file with the included one. Enjoy... Title: Re: Rhinoceros All Versions Post by: Amon on October 01, 2013, 08:12:59 20:12 RhinoCAM refuses to install in the posted 64bit Rhino version. Complains about not be able to fin \Plug-ins\RhinoCAM 2012 for R5.
Title: Re: Rhinoceros All Versions Post by: gmua on October 07, 2013, 12:28:15 00:28 RhinoCAM refuses to install in the posted 64bit Rhino version. Complains about not be able to fin \Plug-ins\RhinoCAM 2012 for R5. Hello Amon, if you installed RhinoCAM 2012 for Rhino 5 (32 Bit) with Rhino 5 (64 Bit), that could be the cause of your problem, I am running RhinoCAM 2012 for Rhino 5 (32 Bit) with Rhino 5 (32 Bit) and it works flawlessly. Hope this helps... UPDATE: I finally found a working medicine for the latest RhinoCAM 2014 for Rhino 5 (64 Bit). (For details scroll down to Reply #17 (http://www.sonsivri.to/forum/index.php?topic=13436.msg169662#msg169662)) Title: Re: Rhinoceros All Versions Post by: pickit2 on October 07, 2013, 06:31:03 18:31 Rhinoceros 5.5 Corporate Edition Multilingual -x64
Title: Re: Rhinoceros All Versions Post by: sale030 on January 25, 2014, 06:04:06 18:04 Here is latest version of Rhinoceros, both tested and full working (32/64).
http://isohunt.to/torrent_details/9497836/Rhinoceros-5-7-31113-14095-Corporate-Edition-x86x64-Patch-Key-FRKH Cheers! Title: Re: Rhinoceros All Versions Post by: sfiga69 on December 11, 2014, 09:06:42 21:06 Rhinoceros 5.9 SR4 multilingual x86/x64 Full working (2014-6-17) Rhinoceros 5.10 RC4 multilingual x86/x64 working? maybe... evaluate (2014-12-01) Title: RhinoCAM 2014 for Rhino 5.0 (64 Bit) Post by: gmua on January 20, 2015, 12:09:42 00:09 MecSoft Corporation | RhinoCAM 2014 Product Version 4.0.0.34 | (Nov 19, 2013) | [113 Mb]
RhinoCAM is a Computer Aided Machining (CAM) plug-in for CNC that runs completely inside of Rhinoceros 5.0. This plug-in is a general purpose machining program targeted at the general machinist. RhinoCAM marries the power of Rhino’s freeform modeling with the legendary machining capabilities of VisualCAD/CAM to bring you a product of unrivaled capability for free form surface machining. With the seamless user interface, selection and display integration RhinoCAM acts and feels like you are working with Rhino when creating your cutter paths. RhinoCAM is fully associative to any geometry changes within Rhino. RhinoCAM includes 2-1/2, 3, 4 and the newly introduced 5 axis continuous milling and hole making operations. It comes with hundreds of post-processors and additionally a post-processor generator to create user definable post-processors. NOTE: RhinoCAM 2014 for Rhino 5.0 requires the Rhinoceros 5.0 CAD system to be installed. If you have not installed Rhinoceros 5.0 please install that first before installing RhinoCAM 2014. After installing, replace the original RhinoCAM 2014 For Rhino5.0.rhp file with the included one. Enjoy... Title: Re: Rhinoceros All Versions Post by: OscarH on January 24, 2015, 10:38:45 10:38 Hi,
Suggested by Gmua's notes, but confirmed by recent testing, the RhinoCAM 2014 For Rhino5.0.rhp patch is only valid for the 64 bits version. OH Title: Re: Rhinoceros All Versions Post by: sfiga69 on January 29, 2015, 10:13:12 10:13 RhinoCam 2014 4.0.34 for Rhino 5.xx x86 & x64:
Download & use Tutorial Video: http://www.youtube.com/user/ModuleWorksTutorials/videos Getting Starter Guide: http://capla.arizona.edu/forms/shop/RhinoCAM_GettingStartedGuide.pdf Title: Re: Rhinoceros All Versions Post by: juliao on January 30, 2015, 02:24:43 14:24 Hi ,i use rhinocam for about 6 years(Rhinocam 2),tryed rhino 2012 and didn´t like it,now i was waiting for rc2014 with big expectation cause of 64 bit version.Shouldn´t this be much faster?
In reality that doesn´t happen.Sometimes i wonder if this happens because its cracked. Also menus are more complicated.Still very poor in options(dont understand why it still dont have diferent x, y and z values for stock) so here i am back to rhinocam2 legal copy. Well,sometimes i think its a lost cause,the new it becames,worst it gets..Even now i remember that the only reason i use RC2 is because it has chanfer function and i use it a lot in 2d work,cause if it wasnt for that reason,the first Rhino was the fastest and more stable version i knew. Title: Re: Rhinoceros All Versions Post by: Ichan on April 12, 2015, 05:59:02 17:59 Hunting for it on the web jungle finally i found RhinoGold which is working (so far) with Rhinoceros 5.9 from reply #16 on windows 7 64 bit.
Repacking it together with the training material re-uploaded it into mediafire, link attached. I confirmed also RhinoCam from reply #19 is working. Lets's make something for the girls.... ;D -ichan Title: Re: Rhinoceros All Versions (RhinoCAM 2015) Post by: sfiga69 on April 24, 2015, 09:36:17 21:36 found on the net
Only for x64, tested with rhino 5.9. seems to work. Rhino3DPRINT is a fully integrated, separately licensed, plug-in that runs inside the Rhinoceros 5.0 NURBS modeler. It offers efficient, easy and automatic tools for the preparation of 3D data, such as point clouds and meshes, that otherwise cannot be 3D printed. The seamless combination of Rhino’s powerful modeling and extensive file import functionality with Rhino3DPRINT’s data preparation tools enables the user to 3D print models from almost any input source and any major 3D format. http://mecsoft.com/rhino3dprint/ Posted on: April 23, 2015, 11:04:38 23:04 - Automerged found on the net Only for x64, tested with rhino 5.9. seems to work. RhinoCAM is a Computer Aided Machining (CAM) plug-in for CNC that runs completely inside of Rhinoceros 5.0. This plug-in is a general purpose machining program targeted at the general machinist. RhinoCAM marries the power of Rhino’s freeform modeling with the legendary machining capabilities of VisualCAM to bring you a product of unrivaled capability for free form surface machining. With the seamless user interface, selection and display integration RhinoCAM acts and feels like you are working with Rhino when creating your cutter paths. RhinoCAM is fully associative to any geometry changes within Rhino. RhinoCAM includes modules for MILL, TURN, NEST, and VisualART to address specific needs of various CNC manufacturing processes. http://mecsoft.com/rhinocam-software/ Title: rhinocam 2016 medicine Post by: juliao on December 15, 2015, 08:30:36 20:30 Rhinocam 2016 medicine
Title: Re: Rhinoceros All Versions Post by: INCAS on November 27, 2016, 03:10:48 15:10 Rhinoceros 5.13
http://files.mcneel.com/dujour/exe/20160913/rh50_en-us_5.13.60913.21340.exe (http://files.mcneel.com/dujour/exe/20160913/rh50_en-us_5.13.60913.21340.exe) See rlink.txt for activation. Title: Re: Rhinoceros All Versions Post by: Gallymimu on November 27, 2016, 04:19:37 16:19 Rhinoceros 5.13 http://files.mcneel.com/dujour/exe/20160913/rh50_en-us_5.13.60913.21340.exe (http://files.mcneel.com/dujour/exe/20160913/rh50_en-us_5.13.60913.21340.exe) See rlink.txt for activation. Has this generator been tested. Windows Defender claims it's a virus (though it often balks at keygens anyway) Title: Re: Rhinoceros All Versions Post by: DarthPic on November 27, 2016, 04:43:24 16:43 Has this generator been tested. Windows Defender claims it's a virus (though it often balks at keygens anyway) Just tested yet , everything is fine here. And NOD32 doesnt complain about any virus. Cheers. Title: Re: Rhinoceros All Versions Post by: INCAS on November 27, 2016, 08:09:23 20:09 Quote from: Gallymimu Has this generator been tested. Windows Defender claims it's a virus (though it often balks at keygens anyway) The keygen is tested and safe. Windows Defender thinks that every file compressed with UPX compressor is a virus. Install a real antivirus (ESET, Kaspersky, etc.) and forget about Windows Defender.Title: Re: Rhinoceros All Versions Post by: Gallymimu on November 28, 2016, 02:16:16 02:16 The keygen is tested and safe. Windows Defender thinks that every file compressed with UPX compressor is a virus. Install a real antivirus (ESET, Kaspersky, etc.) and forget about Windows Defender. Although I agree it's annoying that defender flags a lot of unnecessary things. I don't know why someone would bother to install a piece of paid software like those that you list and simply add even more bloat to a computer for only marginal virus scanning improvement. Thanks for the input on the keygen however. Title: Re: Rhinoceros All Versions Post by: INCAS on November 28, 2016, 02:39:32 02:39 I don't know why someone would bother to install a piece of paid software like those that you list and simply add even more bloat to a computer for only marginal virus scanning improvement. Who said I payed anything for ESET Smart Security 9?I don't feel any 'bloat' or loss of performance from using it and I'm still running Windows XP and every 3D, CAD, graphics software I need. If anything is bloated and buggy, that's Windows Vista and the following Micro$oft failures. As for "marginal virus scanning improvement" I have been using ESS/NOD32 for the last 10 years and it saved me every time without annoying me with paranoid false alarms. Title: Re: Rhinoceros All Versions Post by: sfiga69 on May 04, 2017, 09:35:53 21:35 RhinoCam 2017 V.7.0.469 win64:
info at: https://mecsoft.com/rhinocam-mill/ https://www.youtube.com/watch?v=wBExHDDl-3w https://www.youtube.com/watch?v=pSmbZeJkPTU Rhino3Dprint V. 3.0.336 win64 info at: https://mecsoft.com/rhino3dprint/ https://www.youtube.com/watch?v=Jnzp-Z2JD-0&list=PLx9G05pFm0QKIohYBpCJoMa2T0AUeyc4a edit: link renewed Title: Re: Rhinoceros All Versions Post by: Vineyards on September 26, 2017, 10:06:24 22:06 CAM Links have expired...
Title: Re: Rhinoceros All Versions Post by: Gorgus on September 28, 2017, 05:45:33 17:45 The Rhino3Dprint links has also expired...
Title: Re: Rhinoceros All Versions Post by: sfiga69 on April 13, 2018, 08:46:34 20:46 new link for cam and 3dprint
Posted on: September 28, 2017, 01:04:09 13:04 - Automerged RhinoCAM.2018.v8.0.309 (only for Rhino 5) tested on rhino 5.13 work fine. Posted on: February 06, 2018, 03:01:28 15:01 - Automerged Rhino 6.4.18093.10341 is now available https://www.rhino3d.com/lae/6/new Posted on: April 07, 2018, 04:40:06 16:40 - Automerged RhinoCam 2018.v8.0.13.for.Rhino6 is out Title: Re: Rhinoceros All Versions Post by: DarthPic on August 04, 2018, 01:03:43 13:03 Rhinoceros 3D v6.7.18199.22081.SR7.x64
Follow instructions from the "readme.txt" in patch folder. Enjoy. Title: Re: Rhinoceros All Versions Post by: juliao on September 09, 2018, 05:22:41 17:22 rhino_en-us_6.10.18242.16581
Title: Re: Rhinoceros All Versions Post by: juliao on September 17, 2018, 11:55:55 23:55 rhino_en-us_6.10.18252.10571
Title: Re: Rhinoceros All Versions Post by: pickit2 on June 01, 2019, 04:16:53 16:16 Rhinoceros 6.14.19127.17141 (x64)
Title: Re: Rhinoceros All Versions Post by: sfiga69 on June 03, 2019, 10:23:08 22:23 in attacched, other language.
Title: Re: Rhinoceros All Versions Post by: Vineyards on September 05, 2019, 12:44:41 12:44 Rhinoceros 6.14.19127.17141 (x64) FYI the link seems broken. Title: Re: Rhinoceros All Versions Post by: pickit2 on September 05, 2019, 07:06:31 19:06 Rhinoceros 6.17.19235.15041 (x64)
new updated version Title: Re: Rhinoceros All Versions Post by: Xwing on November 29, 2019, 09:39:01 09:39 Rhino 6.19.19295.01001 (X64)
Title: Re: Rhinoceros All Versions Post by: sfiga69 on February 14, 2020, 09:19:17 21:19 RhinoCAM 2018 (v8.0.41) Win64 for Rhino6 Win64
rhino 6.22.20028.13281 Rhino6 Win64 Title: Re: Rhinoceros All Versions Post by: pickit2 on May 01, 2020, 09:43:15 21:43 Rhinoceros.6.25 winX64 plus patch
Title: Re: Rhinoceros All Versions Post by: sfiga69 on July 12, 2020, 02:03:44 14:03 rhinoceros 6.27.20176.05001
Title: Re: Rhinoceros All Versions Post by: sfiga69 on November 27, 2020, 09:59:48 21:59 Rhinoceros 6.31.20315.17001
Title: Re: Rhinoceros All Versions Post by: pickit2 on November 27, 2020, 11:45:25 23:45 Latest is version 7.
https://www.rhino3d.com/download/ Title: Re: Rhinoceros All Versions Post by: Xwing on November 28, 2020, 03:42:36 15:42 Rhinoceros 7 sr2 ver: 7.2.20332.01011
Deactivate the internet connection during installation and validation. Title: Re: Rhinoceros All Versions Post by: Manuel on November 29, 2020, 12:03:11 12:03 Is There any suggested renderer to work with this nice cad ?
take care, X! Title: Re: Rhinoceros All Versions Post by: Xwing on November 29, 2020, 05:35:28 17:35 I personally use Flamingo nXt as a render, it offers good quality results with relatively short render times.
Title: Re: Rhinoceros All Versions Post by: sfiga69 on May 05, 2023, 10:32:16 22:32 Rhinoceros 7sr28
Rhinocam 2018 read instructions.txt for download rhino from mcneel site and install rhinocam 2018 into rhino7 pass usual |
