Title: ATiny 15 Post by: einet on December 14, 2012, 10:30:02 22:30 hello,
how can say me where i can bay this mcu ? thanks Title: Re: ATiny 15 Post by: sfiga69 on December 15, 2012, 10:54:51 10:54 Hi
Atmel has not the datasheet for ATtiny15. From Digikey (not in stock.. EOL?) 8-Bit 1.6 MHz - Detection of voltage dips / reset, POR, PWM, WDT 6 1KB (512 x 16) FLASH 64 x 8 - 2.7 V ~ 5.5 V A / D 4x10b From mouser: This part has been discontinued by the Supplier with No Replacement at this time. Once stock has been depleted, this part will no longer be available. you can use ATtiny13/ATtiny13A available in digikey IC AVR MCU 20MHZ 1K FLASH AVR 8-Bit 20MHz - Detection of voltage dips / reset, POR, PWM, WDT 6 1KB (512 x 16) FLASH 64 x 8 64 x 8 1.8 V ~ 5.5 V A / D 4x10b Bye Title: Re: ATiny 15 Post by: sarah90 on December 16, 2012, 12:02:39 12:02 A couple of sellers on ebay. Eg: http://www.ebay.com/itm/170952570533
Title: Re: ATiny 15 Post by: metal on January 23, 2013, 01:40:42 13:40 this might be also useful: http://www.atmel.com/images/doc2590.pdf
