Title: I NEED HELP WITH SERIAL 18F4520 Post by: chacacampeon on June 28, 2007, 09:49:45 21:49 THIS IS THE QUESTION, HOW I CAN ERASE THE RCREG OF 18F4520 USING RPOTON_METAL, I CAN COMMUNICATE WITH ANOTHER PIC, BUT CANT ERASE THIS REGISTER TO RECEIVE OK THE INCOMING DATA.
Title: Re: I NEED HELP WITH SERIAL 18F4520 Post by: raraavis on June 29, 2007, 12:21:59 12:21 Try this,
To Clean RCREG, Code: RCREG = 0 Regardess 8) Title: Re: I NEED HELP WITH SERIAL 18F4520 Post by: chacacampeon on June 29, 2007, 04:03:19 16:03 Thanx, but I prube that.
I also prube this code, that i find in the ASM section: Code: asm Regards :'( Title: Re: I NEED HELP WITH SERIAL 18F4520 Post by: chacacampeon on June 29, 2007, 08:15:56 20:15 ;)I find the problem, this code dont work:
Code: hserin [STR String] ' were String is an array of 13 position Replaced with: Code: for i = 0 to 12 PD: hserin [STR String] work OK in 18F252 Regards |
