Title: CCS PCWH 4.074 Post by: mee48025 on June 21, 2008, 05:05:13 17:05 Hi All
I have uploaded ccs pcwh 4.074 at under link http://rapidshare.com/files/124042065/PCWH_v4.074.rar.html Title: Re: CCS PCWH 4.074 Post by: The Puma on June 22, 2008, 10:42:58 10:42 Did you can help us with the PCWHD compiler (4.074)?
Title: Re: CCS PCWH 4.074 Post by: mee48025 on June 22, 2008, 02:18:45 14:18 Did you can help us with the PCWHD compiler (4.074)? I only have pcwhd 4.068. do you want it? Title: Re: CCS PCWH 4.074 Post by: xp338 on June 22, 2008, 03:19:54 15:19 I install it over the old version(4.057) and the "old crg files" are working fine with 4.074.
I did compliered some project and it work... Title: Re: CCS PCWH 4.074 Post by: The Puma on June 27, 2008, 06:30:47 18:30 I only have pcwhd 4.068. do you want it? Thanks, but this version did i own alreadyTitle: Re: CCS PCWH 4.074 Post by: xzb on June 30, 2008, 02:06:42 02:06 why ccs pcwh 4.074 now not support this use?
#define Nop() #asm nop #endasm Title: Re: CCS PCWH 4.074 Post by: mayler on July 04, 2008, 02:36:12 02:36 Here i compiled and worked... A solution for your problem can be delay_cicles(1); , who will generate a NOP in assembly code.
Title: Re: CCS PCWH 4.074 Post by: petarp on July 04, 2008, 09:08:33 09:08 hi, mayler. You mean delay_cycles(1);
Title: Re: CCS PCWH 4.074 Post by: papai on July 05, 2008, 04:41:35 04:41 Hi All I am facing the problems with th registry files. After I have installed the software ,it says that .CRG or .REG files not found. Pls suggest the remedyI have uploaded ccs pcwh 4.074 at under link http://rapidshare.com/files/124042065/PCWH_v4.074.rar.html Title: Re: CCS PCWH 4.074 Post by: cjeffries1 on July 28, 2008, 05:51:54 17:51 I am facing the problems with th registry files. After I have installed the software ,it says that .CRG or .REG files not found. Pls suggest the remedy Did you do an upgrade or a clean install of this version? If you had a previous version you may be better to uninstall everything with a professional uninstaller, clean the registry and start againTitle: Re: CCS PCWH 4.074 Post by: wnmaximino on September 04, 2008, 08:02:30 20:02 Don´t working in windows vista!
CRG files error. Title: Re: CCS PCWH 4.074 Post by: beque on September 04, 2008, 09:21:36 21:21 Attention Folks:
For working in Windows Vista dont install in default folder, change to C:\PICC and join the files register to this folder. Title: Re: CCS PCWH 4.074 Post by: wnmaximino on September 16, 2008, 09:07:09 21:07 Don´t working in windows vista ultimate (C:\PICC)
CRG files error Attention Folks: For working in Windows Vista dont install in default folder, change to C:\PICC and join the files register to this folder. Title: Re: CCS PCWH 4.074 Post by: The Puma on October 04, 2008, 12:38:29 12:38 Has someone an update to the latest 4.080 version?
If someone has 4.079 it also ok Title: Re: CCS PCWH 4.074 Post by: spasbyspas on October 04, 2008, 05:04:28 17:04 Have a problem with new ver.4.080
http://www.ccsinfo.com/forum/viewtopic.php?t=36212 we will waiting for a next version!(If some one have v4.079 or 4.078 pleace give me ;) ) Title: Re: CCS PCWH 4.074 Post by: The Puma on October 09, 2008, 11:28:33 11:28 @spasbyspas ,
There is already an updated version 4.081 Maybe this fix the problems. Please upload Title: Re: CCS PCWH 4.074 Post by: preatorian on November 15, 2008, 04:20:33 16:20 Hi all,
current version is 4.082, can anyone upload it? regards |
