Title: rc-switch for PIC microcontroller
Post by: iBnav on February 19, 2022, 12:09:39 12:09
hello guys as you know RC-switch is a good library for 355 and 433mhz Frequency. Before I saw it "RC-switch", I wrote simple code for 433mhz... My code in Proteus was Ok. But in practice, it had many problems. and my question is, no way to convert RC-switch for PIC microcontroller? XC8 MPLBX /* * File: main.c * Author: iBnav * * Created on February 18, 2022 4:51 PM */
// PIC12F1822 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1 #pragma config FOSC = INTOSC // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin) #pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled) #pragma config PWRTE = ON // Power-up Timer Enable (PWRT enabled) #pragma config MCLRE = OFF // MCLR Pin Function Select (MCLR/VPP pin function is digital input) #pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled) #pragma config CPD = OFF // Data Memory Code Protection (Data memory code protection is disabled) #pragma config BOREN = ON // Brown-out Reset Enable (Brown-out Reset enabled) #pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin) #pragma config IESO = OFF // Internal/External Switchover (Internal/External Switchover mode is disabled) #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is disabled)
// CONFIG2 #pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off) #pragma config PLLEN = ON // PLL Enable (4x PLL enabled) #pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset) #pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.) #pragma config LVP = OFF // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)
// #pragma config statements should precede project file includes. // Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define _XTAL_FREQ 8000000
void PIN_MANAGER_Initialize(void) {
LATA = 0x00; TRISA = 0b00000011; ANSELA = 0x00;
#define RF_DATA PORTAbits.RA0 #define K_LEARN PORTAbits.RA1 #define LED_REC LATAbits.LATA2
char chekbit() { unsigned char i = 0; char b = 0; while (1) { if (i > 150) { if (RF_DATA) b = 1; break; } __delay_us(10); i++; }
while (RF_DATA); return b; }
void remote_code() { unsigned char inbits[24], shift; unsigned char i = 0; Rsw = Rcode[0] = Rcode[1] = Rcode[2] = 0;
while (!((RF_DATA) && i >= 8)) { if (RF_DATA) i = 0; __delay_ms(1); i++; }
i = 0; while (i < 24) { while (!(RF_DATA)); inbits[i] = chekbit(); i++; }
shift = 3; for (i = 0; i < 4; i++) { Rcode[0] |= inbits[i] << shift; shift--; } shift = 7; for (i = 4; i < 12; i++) { Rcode[1] |= inbits[i] << shift; shift--; } shift = 7; for (i = 12; i < 20; i++) { Rcode[2] |= inbits[i] << shift; shift--; } shift = 3; for (i = 19; i < 24; i++) { Rsw |= inbits[i] << shift; shift--; } }
Title: Re: rc-switch for PIC microcontroller
Post by: sadman on February 19, 2022, 03:43:05 15:43
hi no way to convert RC-switch for PIC microcontroller? lot hobbyist have done this if I remember correctly such a design share here please search, there was a design publish in silicon chip magazine base on 12F508 chip sadman
Post by: iBnav on February 19, 2022, 07:13:35 19:13
Thanks, Sadman. I searched silicon magazine before. Silicon magazine is so amazing. but there are two problems with that... some projects in silicon magazine are too old and the second reason silicon code project usually is hex.
Post by: sadman on February 20, 2022, 04:51:37 04:51
here is some start https://www.edaboard.com/threads/rf-tx-rx-interface-with-pic-microcontroller.334371/ https://www.edaboard.com/threads/ewn-manchester-encoding-decoding-rf-applications.390796/ https://www.ccsinfo.com/forum/viewtopic.php?t=51572 https://libstock.mikroe.com/projects/view/1609/pic-manchester-code-rf-remote http://www.winpicprog.co.uk/pic_tutorial12.htm sadman
