Title: CCS printf() is not too bright
Post by: caveman508 on February 18, 2008, 12:27:16 00:27
Hi all, I have been doing development on a good size project and became very aware that I was gobbling up program space very quickly with the scattered printf(). Well, I didn't care until the end when I ran out of ROM, so I did some playing around. CCS is not the brightest bulb in the box when it come to some things, and the following code shows it. Look how it uses a different call address when doing: printf("TEST_OK 1?\r"); printf("TEST_OK 2?\r"); printf("TEST_OK 3?\r"); printf("TEST_OK 4?\r"); So, me and a friend came up with the print() method (without a f), I saved over 1K of space in 30 prints of a constant string, all with no reference to a variable, just a constant string. I first tried the MyPrint but they won't allow a pointer to const, but what the %^&*)( is "printf("TEST_OK 1?\r"); " doing then??????? Look how elegant it does the code for: print(T4); print(T5); print(T6); Anyone out there that could shed some further light on other ways would be great. Thanks, Caveman
#include <18f4423.h> #define CLOCKSPEED 40000000 #define BAUDRATE 57600
#fuses H4, PUT, BROWNOUT, NOPBADEN, MCLR, NOWDT, NOLVP, DEBUG, NOPROTECT, STVREN, NOCPB, NOCPD, NOWRT #zero_ram #device ADC=12 #use delay( clock = CLOCKSPEED, RESTART_WDT ) #case #use rs232( baud=BAUDRATE, parity=n, xmit=PIN_C6, rcv=PIN_C7, bits=8 )
typedef enum _str_num { T1, \ T2, \ T3, \ T4, \ T5, \ T6, \ T7, \ T8, \ T9 };
const char c_str[][*] = { "TEST 1", "TEST 2", "TEST 3", "TEST 4", "TEST 5", "TEST 6", "TEST 7", "TEST 8", "TEST 9" }; void print(_str_num num) { printf("%s\n\r", c_str[num]); } typedef enum _some_status { STAT_OK, STAT_1 =3, STAT_2 =6, STAT_3 =10, STAT_4, STAT_5, STAT_6, STAT_7 };
void PrintAStatus( _some_status stat ){ const char stat_str[][*] = { "OK", "1", "2", "Stat: 1", "4", "5", "Stat: 2", "7", "8", "9", "Stat: 3", "Stat: 4", "Stat: 5", "Stat: 6", "Stat: 7", }; if ( stat > STAT_7 ) { printf( "Stat : ERR\n\r"); } else { printf( "Status : %s\n\r", stat_str[stat] ); } }
//void MyPrint(const char * cptr) { // printf("%s", cptr); //}
void main(void) { _some_status my_stat = STAT_2;
PrintAStatus(my_stat); PrintAStatus(++my_stat); PrintAStatus(STAT_5); PrintAStatus(9); PrintAStatus(14); PrintAStatus(104);
printf("TEST_OK?\r"); printf("TEST_OK?\r"); printf("TEST_OK?\r"); printf("TEST_OK 1?\r"); printf("TEST_OK 2?\r"); printf("TEST_OK 3?\r"); printf("TEST_OK 4?\r"); print(T4); print(T5); print(T6); // MyPrint("Test MyPrint\n\r"); for (;;); }
Here is the listing:
[CCS PCH C Compiler, Version 4.050, 40210 17-Feb-08 17:21
Filename: C:\Projects\Firmware\DREAM\THE_TH~1.lst
ROM used: 1022 bytes (6%) Largest free fragment is 15362 RAM used: 7 (1%) at main() level 12 (2%) worst case Stack: 2 locations
* 0000: GOTO 02D6 .................... #include <18f4423.h> .................... //////// Standard Header file for the PIC18F4423 device //////////////// .................... #device PIC18F4423 .................... #list .................... .................... #define CLOCKSPEED 40000000 .................... #define BAUDRATE 57600 .................... .................... #fuses H4, PUT, BROWNOUT, NOPBADEN, MCLR, NOWDT, NOLVP, DEBUG, NOPROTECT, STVREN, NOCPB, NOCPD, NOWRT .................... #zero_ram .................... #device ADC=12 .................... #use delay( clock = CLOCKSPEED, RESTART_WDT ) .................... #case .................... #use rs232( baud=BAUDRATE, parity=n, xmit=PIN_C6, rcv=PIN_C7, bits=8 ) .................... .................... typedef enum _str_num { .................... T1, \ .................... T2, \ .................... T3, \ .................... T4, \ .................... T5, \ .................... T6, \ .................... T7, \ .................... T8, \ .................... T9 .................... }; .................... .................... const char c_str[][*] = .................... { .................... "TEST 1", .................... "TEST 2", .................... "TEST 3", .................... "TEST 4", .................... "TEST 5", .................... "TEST 6", .................... "TEST 7", .................... "TEST 8", .................... "TEST 9" .................... }; .................... void print(_str_num num) { .................... printf("%s\n\r", c_str[num]); * 0288: CLRF 09 028A: MOVFF 07,08 028E: MOVLW 01 0290: MOVWF 0B 0292: CLRF 0A 0294: RCALL 01E4 0296: MOVFF 02,03 029A: MOVFF 01,08 029E: MOVFF 02,09 02A2: MOVFF 02,0B 02A6: MOVFF 01,0A 02AA: MOVFF 0B,FF7 02AE: MOVF 0A,W 02B0: RCALL 0004 02B2: IORLW 00 02B4: BZ 02C4 02B6: INCF 0A,F 02B8: BTFSC FD8.2 02BA: INCF 0B,F 02BC: BTFSS F9E.4 02BE: BRA 02BC 02C0: MOVWF FAD 02C2: BRA 02AA 02C4: MOVLW 0A 02C6: BTFSS F9E.4 02C8: BRA 02C6 02CA: MOVWF FAD 02CC: MOVLW 0D 02CE: BTFSS F9E.4 02D0: BRA 02CE 02D2: MOVWF FAD .................... } 02D4: RETLW 00 .................... typedef enum _some_status { STAT_OK, STAT_1 =3, STAT_2 =6, STAT_3 =10, STAT_4, STAT_5, STAT_6, STAT_7 }; .................... .................... void PrintAStatus( _some_status stat ){ .................... const char stat_str[][*] = .................... { .................... "OK", .................... "1", .................... "2", .................... "Stat: 1", .................... "4", .................... "5", .................... "Stat: 2", .................... "7", .................... "8", .................... "9", .................... "Stat: 3", .................... "Stat: 4", .................... "Stat: 5", .................... "Stat: 6", .................... "Stat: 7", .................... }; .................... if ( stat > STAT_7 ) { * 0202: MOVF 07,W 0204: SUBLW 0E 0206: BC 0222 .................... printf( "Stat : ERR\n\r"); 0208: CLRF 08 020A: MOVF 08,W 020C: RCALL 011E 020E: INCF 08,F 0210: MOVWF 00 0212: MOVF 00,W 0214: BTFSS F9E.4 0216: BRA 0214 0218: MOVWF FAD 021A: MOVLW 0C 021C: SUBWF 08,W 021E: BNZ 020A .................... } else { 0220: BRA 0286 .................... printf( "Status : %s\n\r", stat_str[stat] ); 0222: CLRF 09 0224: MOVFF 07,08 0228: MOVLW 01 022A: MOVWF 0B 022C: CLRF 0A 022E: RCALL 01E4 0230: MOVFF 02,03 0234: MOVFF 01,08 0238: MOVFF 02,09 023C: CLRF 0A 023E: MOVF 0A,W 0240: RCALL 013C 0242: INCF 0A,F 0244: MOVWF 00 0246: MOVF 00,W 0248: BTFSS F9E.4 024A: BRA 0248 024C: MOVWF FAD 024E: MOVLW 09 0250: SUBWF 0A,W 0252: BNZ 023E 0254: MOVFF 09,0C 0258: MOVFF 08,0B 025C: MOVFF 0C,FF7 0260: MOVF 0B,W 0262: RCALL 0086 0264: IORLW 00 0266: BZ 0276 0268: INCF 0B,F 026A: BTFSC FD8.2 026C: INCF 0C,F 026E: BTFSS F9E.4 0270: BRA 026E 0272: MOVWF FAD 0274: BRA 025C 0276: MOVLW 0A 0278: BTFSS F9E.4 027A: BRA 0278 027C: MOVWF FAD 027E: MOVLW 0D 0280: BTFSS F9E.4 0282: BRA 0280 0284: MOVWF FAD .................... } .................... } 0286: RETLW 00 .................... .................... //void MyPrint(const char * cptr) { .................... // printf("%s", cptr); .................... //} .................... .................... void main(void) { * 02D6: CLRF FF8 02D8: BCF FD0.7 02DA: MOVLW FE 02DC: MOVWF 00 02DE: MOVLW 03 02E0: MOVWF 01 02E2: MOVLW 02 02E4: MOVWF FE9 02E6: MOVLW 00 02E8: MOVWF FEA 02EA: CLRF FEE 02EC: DECFSZ 00,F 02EE: BRA 02EA 02F0: DECFSZ 01,F 02F2: BRA 02EA 02F4: CLRF FEA 02F6: CLRF FE9 02F8: BSF FB8.3 02FA: MOVLW AD 02FC: MOVWF FAF 02FE: MOVLW 00 0300: MOVWF FB0 0302: MOVLW A6 0304: MOVWF FAC 0306: MOVLW 90 0308: MOVWF FAB 030A: MOVF FC1,W 030C: ANDLW C0 030E: IORLW 0F 0310: MOVWF FC1 0312: MOVLW 07 0314: MOVWF FB4 .................... _some_status my_stat = STAT_2; 0316: MOVLW 06 0318: MOVWF 06 .................... .................... PrintAStatus(my_stat); 031A: MOVFF 06,07 031E: RCALL 0202 .................... PrintAStatus(++my_stat); 0320: INCF 06,F 0322: MOVFF 06,07 0326: RCALL 0202 .................... PrintAStatus(STAT_5); 0328: MOVLW 0C 032A: MOVWF 07 032C: RCALL 0202 .................... PrintAStatus(9); 032E: MOVLW 09 0330: MOVWF 07 0332: RCALL 0202 .................... PrintAStatus(14); 0334: MOVLW 0E 0336: MOVWF 07 0338: RCALL 0202 .................... PrintAStatus(104); 033A: MOVLW 68 033C: MOVWF 07 033E: RCALL 0202 .................... .................... printf("TEST_OK?\r"); 0340: CLRF 07 0342: MOVF 07,W 0344: RCALL 015A 0346: INCF 07,F 0348: MOVWF 00 034A: MOVF 00,W 034C: BTFSS F9E.4 034E: BRA 034C 0350: MOVWF FAD 0352: MOVLW 09 0354: SUBWF 07,W 0356: BNZ 0342 .................... printf("TEST_OK?\r"); 0358: CLRF 07 035A: MOVF 07,W 035C: RCALL 015A 035E: INCF 07,F 0360: MOVWF 00 0362: MOVF 00,W 0364: BTFSS F9E.4 0366: BRA 0364 0368: MOVWF FAD 036A: MOVLW 09 036C: SUBWF 07,W 036E: BNZ 035A .................... printf("TEST_OK?\r"); 0370: CLRF 07 0372: MOVF 07,W 0374: RCALL 015A 0376: INCF 07,F 0378: MOVWF 00 037A: MOVF 00,W 037C: BTFSS F9E.4 037E: BRA 037C 0380: MOVWF FAD 0382: MOVLW 09 0384: SUBWF 07,W 0386: BNZ 0372 .................... printf("TEST_OK 1?\r"); 0388: CLRF 07 038A: MOVF 07,W 038C: RCALL 0174 038E: INCF 07,F 0390: MOVWF 00 0392: MOVF 00,W 0394: BTFSS F9E.4 0396: BRA 0394 0398: MOVWF FAD 039A: MOVLW 0B 039C: SUBWF 07,W 039E: BNZ 038A .................... printf("TEST_OK 2?\r"); 03A0: CLRF 07 03A2: MOVF 07,W 03A4: RCALL 0190 03A6: INCF 07,F 03A8: MOVWF 00 03AA: MOVF 00,W 03AC: BTFSS F9E.4 03AE: BRA 03AC 03B0: MOVWF FAD 03B2: MOVLW 0B 03B4: SUBWF 07,W 03B6: BNZ 03A2 .................... printf("TEST_OK 3?\r"); 03B8: CLRF 07 03BA: MOVF 07,W 03BC: RCALL 01AC 03BE: INCF 07,F 03C0: MOVWF 00 03C2: MOVF 00,W 03C4: BTFSS F9E.4 03C6: BRA 03C4 03C8: MOVWF FAD 03CA: MOVLW 0B 03CC: SUBWF 07,W 03CE: BNZ 03BA .................... printf("TEST_OK 4?\r"); 03D0: CLRF 07 03D2: MOVF 07,W 03D4: RCALL 01C8 03D6: INCF 07,F 03D8: MOVWF 00 03DA: MOVF 00,W 03DC: BTFSS F9E.4 03DE: BRA 03DC 03E0: MOVWF FAD 03E2: MOVLW 0B 03E4: SUBWF 07,W 03E6: BNZ 03D2 .................... print(T4); 03E8: MOVLW 03 03EA: MOVWF 07 03EC: RCALL 0288 .................... print(T5); 03EE: MOVLW 04 03F0: MOVWF 07 03F2: RCALL 0288 .................... print(T6); 03F4: MOVLW 05 03F6: MOVWF 07 03F8: RCALL 0288 .................... // MyPrint("Test MyPrint\n\r"); .................... for (;;); 03FA: BRA 03FA .................... } 03FC: SLEEP
