Title: DeskProto 32/64 bit (2510) Post by: gmua on April 10, 2013, 05:57:45 17:57 DeskProto v6.0 32-bit (2510) offers 3D CNC machining for non-machinists.
DeskProto is a 3D CAM program (CAM = Computer Aided Manufacturing). It can import STL files from any 3D CAD program, calculate CNC toolpaths and then write NC program files for any CNC milling machine: 3-axis, 4-axis and 5-axis. DeskProto is aimed at designers for Rapid Prototyping, at jewelers for wax models, artists for sculptures, medics for prostheses, moldmakers, woodworkers, teachers, students, hobbyists, etc.. UPDATE: Reply #6 (http://www.sonsivri.to/forum/index.php?topic=51940.msg154949#msg154949) has a new download link with new medicine. Title: Re: DeskProto v6.0 32-bit (2510) Post by: gabi68 on April 10, 2013, 09:05:39 21:05 I think this is a 64 bit version with a 32 bit medicine. Someone can confirm this? I try to install it and failed. Any help...?
Title: Re: DeskProto v6.0 32-bit (2510) Post by: gmua on April 11, 2013, 12:11:16 00:11 I think this is a 64 bit version with a 32 bit medicine. Someone can confirm this? I try to install it and failed. Any help...? I'm sorry gabi68, the installer contains both versions, which one is installed, depends on your Windows version, I could not install the 32 bit version on my 64 bit Windows 7, so I had to try it in my 32 bit machine, the medicine works fine with 32 bit but not with 64, sorry again. Title: Re: DeskProto v6.0 32-bit (2510) Post by: #tester on April 12, 2013, 10:17:12 22:17 gabi68 How about installing it as full version, which will count down uses, unless you run a clockstopper or runasdate program, search will show dl links.
Title: Re: DeskProto v6.0 32-bit (2510) Post by: gabi68 on April 14, 2013, 09:20:11 09:20 gabi68 How about installing it as full version, which will count down uses, unless you run a clockstopper or runasdate program, search will show dl links. I'm sorry gabi68, the installer contains both versions, which one is installed, depends on your Windows version, I could not install the 32 bit version on my 64 bit Windows 7, so I had to try it in my 32 bit machine, the medicine works fine with 32 bit but not with 64[/color], sorry again. Do you have a 64 bit medicine?EDIT: so busy leeching can't read. Title: Re: DeskProto v6.0 32-bit (2510) Post by: gmua on September 12, 2013, 02:21:45 02:21 Do you have a 64 bit medicine? No, but I'm still looking for it (My main computer has Windows 7 64 bits installed), if I find it, I will post it. Posted on: April 15, 2013, 09:58:59 21:58 - Automerged DeskProto v6.0 32-bit (3571) offers 3D CNC machining for non-machinists. Revision 3571 includes: - In the Basic 3D wizard the supports were cut loose (the wizard did not set the Borders). - Toolpath calculations could crash for: Conic_cutter and Angle_with_X and Always_stay_low on. - A new build for only two fixes, because the supports bug was a very serious one, confusing new users. Title: Re: DeskProto v6.0 32-bit (2510) Post by: pilotensitz on September 20, 2013, 06:13:58 18:13 I think this is a 64 bit version with a 32 bit medicine. Someone can confirm this? I try to install it and failed. Any help...? No, but I'm still looking for it (My main computer has Windows 7 64 bits installed), if I find it, I will post it. Hi! It works for me with the following workaround: 1. Install deskproto (link.txt from last posting here) 2. Install it also in a Vm-Ware with Win XP Mode (mine is XP Mode with SP3) and use the crack. It works here now 3. Copy/replace the whole content of the folder with your folder on your main x64 machine At the first start, it crashed the programm but after secont start it worked fine till now. I dont know, if step 1 is necessary. Please report here, if you had success! Greetings, p i l o t e n s i t z Title: Re: DeskProto v6.0 32-bit (2510) Post by: gmua on September 25, 2013, 05:04:54 17:04 1. Install deskproto (link.txt from last posting here) 2. Install it also in a Vm-Ware with Win XP Mode (mine is XP Mode with SP3) and use the crack. It works here now 3. Copy/replace the whole content of the folder with your folder on your main x64 machine Great tip pilotensitz, let's wait to hear how it went for gabi68. Title: Re: DeskProto 32/64 bit (2510) Post by: sale030 on November 10, 2013, 09:44:31 09:44 Hi everybody.
Download link no more exist. Can someone upload new one, please??? Greetings Title: Re: DeskProto 32/64 bit (2510) Post by: sgoum on November 10, 2013, 04:33:02 16:33 Here it is
Title: Re: DeskProto 32/64 bit (2510) Post by: vegas on December 16, 2013, 07:20:06 07:20 :'( hello to all. Unfortunately, my version of w7 is home premium and I can not install the VM. there is another way to make the program work?
Thanks Title: Re: DeskProto 32/64 bit (2510) Post by: mare69 on October 20, 2014, 10:53:39 10:53 Can someone upload new download link, please?
Tnx! 73 Title: Re: DeskProto 32/64 bit (2510) Post by: snowman on October 20, 2014, 02:12:19 14:12 mega.co link is working by gmua
Title: DeskProto v6.1 english, Entry edition Post by: pilotensitz on February 01, 2015, 03:03:45 15:03 DeskProto v6.1 english, Entry edition
see attached file greetings p i l o t e n s i t z Title: Re: DeskProto 32/64 bit (2510) Post by: Ichan on April 02, 2015, 07:15:29 07:15 Hi,
I am trying rotary axis machining, seems Deskproto is good for this. Install the DeskProto v6.0 32-bit (3571) both on Win7 32 and 64 (with pilotensitz method), everything fine until saving the generated toolpath - an error like picture below. Anyone experience the same? -ichan Title: Re: DeskProto 32/64 bit (2510) Post by: Ichan on April 10, 2015, 05:32:09 17:32 The error above doesn't happen with 2510 version.
Then i found serial number on Russian website which work on the latest English trial version (4819) making it a working multi axis edition :P. But, worry this sn will be blacklisted soon :(. -ichan Title: Re: DeskProto 32/64 bit (2510) Post by: alm555 on January 24, 2016, 04:32:00 16:32 DeskProto v6.1 (5531), Entry edition
Title: Re: DeskProto 32/64 bit (2510) Post by: ELCouz on February 08, 2016, 11:56:30 23:56 You can run any recent trial version in a VM image.
This is what I do. Restore the snapshot when 30 days are expired. Be sure to have the following lines in the vmx file (vmware) Otherwise the armadillo software protection included in the software is gonna detect VMware running and invalidate the trial period Code: monitor_control.restrict_backdoor = "TRUE" Title: Re: DeskProto 32/64 bit (2510) Post by: alm555 on March 15, 2016, 02:38:31 14:38 DeskProto 6.1 Multi-Axis Edition
Title: Re: DeskProto 32/64 bit (2510) Post by: Grantorax on April 03, 2016, 03:21:18 03:21 Last Link Faild....
