Title: EMF Post by: Dr Caos on April 23, 2008, 04:33:15 04:33 Do you think that we can split the hydrogen and oxigen from water with a low current using the frecuency of an electromagnetic field?
Title: Re: EMF Post by: Vague on April 23, 2008, 08:18:06 08:18 I am not sure that I understand what you mean but no matter which method you use to split water you always need to supply at least enough energy to break the chemical bonds. This is a large amount of energy and the best you can do is supply the required energy as efficiently as possible and so if you are using a small current I don't know how you could supply enough energy.
Title: Re: EMF Post by: mbandala on April 23, 2008, 06:06:28 18:06 You can find more info here
http://www.thesietch.org/projects/Hydrogenmaker/index.htm Title: Re: EMF Post by: Dr Caos on April 24, 2008, 06:32:55 06:32 Well... Im not sure about the power required to split the chemical bonds.
Actually the effect of resonanse its very interesting. Maybe with a catalizer. Just like the H2O2 Title: Re: EMF Post by: Vague on May 03, 2008, 09:29:08 09:29 I don't think resonance would make much difference, energy must still be conserved.
