Title: How to disassemble / take apart your AC Laptop or other adapter Post by: solutions on March 19, 2011, 11:19:58 23:19 I figured, after a bit of headscratching and after Google came up with nothing but "don't do it" from the nannies out there, I'd share my findings here with my buds, since we like to mod stuff like put a different regulator in, etc. My reason was a broken wire right behind the strain relief (which is actually a strain concentrator, just that the strain is now moved back from the entrance to the case of the adapter).
NO, it's not usually super adhesives, it's a plastic weld, usually ultrasonic, that holds AC adapters together. Laptop and wall wart adapters can be taken apart or disassembled with some simple tools and a little care and eye/hand/ear coordination. Just realize that the voltages inside can be lethal and if you don't know what you are doing, you can do a lot of damage to people or property, including cause a fire. In other words, you are on your own in doing this. The "really sharp utility knife and/or chisel/hammer combo" method on the web might work, but I found a really nice way that causes little damage. First, check and see if you have some screws hidden under logos, stickers, etc. All the prying or chiseling in the world won't get it apart if it's screwed together and it'll be kinda embarrassing to discover this after you've carved a Mt Rushmore replica into your adapter plastic with that chisel. I used an arbor press, but a vise would work just as well. Get yourself a deep socket, something like 3/8 inch or 1/2 inch (13mm for you metric people). It may be easiest if the socket does not extend to the corners, but rather, say half or 2/3 the length of the seam. Take a close look at the seam that runs along the "waterline" of the adapter. If you can figure out which half is behind the other, life will be a lot easier. If you can't it's a coin flip, and since it's busted anyway, you really have nothing to lose. Place the socket along the seam, just above or below it, ideally on the side that's behind the other in the seam. Now you'll put the squeeze on the socket on one side which, as a cylinder, will concentrate the forces just below the seam and nowhere else on the case, and the other side of the adapter in your vise or press (even vise grips may work, preferably the welding clamp kind with the wide jaws). You may also be able to do it with a c-lamp and no socket. You'll hear a cracking noise as you increasingly flex the plastic seam by slightly closing and opening your press/vise/clamp, which means you're getting the job done. Flip the adapter to the other side(s) and do the same. I only had to do the two long sides of mine. With a bit of luck, it'll come apart to where you'll have most of the plastic intact and, using this method, the outside of the adapter won't look like there was a woodpecker party from all that chiseling. I have found that it's the cord at the strain relief and that soldering in a fresh part of the cord an inch or two back from the back of the strain relief works, but you won't have a strain relief anymore. You can get creative with reusing the old strain relief (I sliced along its length with diagonal cutters aka “dykes”) and use heat shrink tubing to hold it together. If you are replacing the cord, don't forget to slide the heatshrink on loose BEFORE you solder the wires onto the circuit board :-) Some adapters have three wires, one is used for ID...make sure you remember which wire went where. Once you're sure of your repairs by trying it out, black electrical tape gives your adapter that ubernerd brag factor that you know how to fix stuff, you CAN use hockey tape to give your adapter a Canadian identity, or you can be stealthy about your skills and use ABS plumbing cement from the hardware store to glue it back together...just realize, if that cord broke once in a year or two, you'll be in it again in a while, which is why I taped mine. The last step is to slide the heatshrink onto the split strain relief and shrink it. Title: Re: How to disassemble / take apart your AC Laptop or other adapter Post by: Altair on March 30, 2011, 02:25:03 02:25 Good job solutions. I had the very same problem to deal with while trying to open the case on my wife's HP adapter. The center conductor of her cord was severed about 1" out from the end of the strain relief. My 1st solution was to cut the cord completely off and back-splice both conductors, with heat shrink on each. I cautioned her NOT to fold the cord over near the repair, but, you can guess what happened (within 2 days!).
This time, there would be no splicing - I needed to get that case open. I didn't think of using an arbor press and/or a socket but I did try a VERY wide blade common screwdriver. I had only moderate success with this method, as the case started to splinter away from the seam. That's when I decided break out the old Dremel tool and saw it open! I found a thin cut-off wheel but didn't have the proper arbor for it. My solution was to remove one of the small sanding drums from its rubber hub and then mount the disc directly on top of the hub with the expansion screw. Using a modest speed to avoid melting the plastic, I carefully cut down into the seam until I could feel the disc break through the case, then cut around the entire perimeter. I stopped just short of both the old strain relief and the AC cord socket, then used the wide blade screwdriver to pop these 2 areas apart. After the cord was reattached to its original location on the circuit board, I clamped the case back together and spread some black, 2-part, 5 minute epoxy all the way around the seam. I waited a couple of minutes for the epoxy to start to set before spreading it, as this prevented it from dripping down the side of the case. The plastic the case is made of contained wax so the epoxy can be separated with a small putty knife and modest force. The whole entire process took less than 1/2 hour, including cleanup, and I once again have a happy wife! Title: Re: How to disassemble / take apart your AC Laptop or other adapter Post by: tanveerriaz on November 06, 2011, 11:45:33 11:45 try this it like magic
use few drop of Petrol (Motorcycle / car Fuel) in joint of body after few minutes it open easily Title: Re: How to disassemble / take apart your AC Laptop or other adapter Post by: solutions on November 06, 2011, 03:16:44 15:16 The problem with using a solvent is that it only works on glued seams. The higher quality case assemblies are actually ultrasonically welded plastic, so not sure petrol/gasoline would work, and why cracking the joint does. I suppose you could try one before the other - just watch the sparks or you'll have some serious problems with those fumes.
Title: Re: How to disassemble / take apart your AC Laptop or other adapter Post by: tedz on November 12, 2011, 01:45:02 13:45 Maybe using petrol/gasoline or similar is not that crazy idea: Such "light oil" -type solvent does not dissolve especially well plastics used in typical electronics casings, they are mostly ABS. However, many liquids creep eagerly in the cracks of plastics, also the tiny spaces left after welding, where they weaken the surrounding of crack (the welding!). Therefore cracking it open will be easier.
Btw, one ugly example of very sensitive material to many oily liquids is Polycarbonate (a.k.a. PC). Many variations of that material crack uncontrollably and nearly everywhere where they have some stored tension (welding, screw towers etc.). That property of PC has caused many field failures of devices such as phones, when an improper combination of materials and assembly methods causing mechanical stress has been present. Even fat from human skin has been strong enough to cause material's microscopic cracks to proceed to point of failure in those cases. Therefore: Using oily liquids may work by helping the physical cracking of welded joints - or it may also fatally weaken also parts you are not planning to crack! So, don't overdo it. |
