Title: ARM rvds toolchain eclipse plugin Post by: dotm on January 06, 2016, 12:22:31 00:22 What happened?
I decided to upgrade to eclipse mars and wanted to install the rvds toolchain plugin (as described here: http://infocenter.arm.com/help/topic/com.arm.doc.dui0330a/CACIFEDD.html) But http://www.arm.com/eclipse leads to a site stating rvds is legacy and I should upgrade to ds-5 (but amclang does not even support all the cortex devices yet). Now I'm pissed. Have I missed just the oportunity to get that working without major errorparser hacking in f**ing regex? Are they crazy? Why is this not available AT ALL anymore? I'm so close to change over to gcc, since the keil editor kills me. Does anyone has the plugin downloaded? Should I change over to GCC? Does this mean I have to use OpenOCD and if, is trace supported? Will i be able to monitor my rtos tasks as I'm used to? Secondly, the ***ing pack installer from keil breaks the uvision plugin: http://www.keil.com/forum/58500/#msg190412 Be aware upgrading to uv5. The pack installer sucks hard, example:
Title: Re: ARM rvds toolchain eclipse plugin Post by: electrojit on January 08, 2016, 03:17:54 15:17 Yes its pathetic... I am also searching for the whole RVDS 3.1 compiler and eclipse plugin...
Can you share the compiler RVCT 3.1 if you have it? Regards, electrojit Title: Re: ARM rvds toolchain eclipse plugin Post by: dotm on January 25, 2016, 06:25:53 18:25 Yes its pathetic... I am also searching for the whole RVDS 3.1 compiler and eclipse plugin... Can you share the compiler RVCT 3.1 if you have it? Regards, electrojit I actually abandonned uvision for good. I'm now working on ARM GCC and eclipse and guess what, its nice and smooth. Has its own packs manager, a nice debugger and all the eclipse features are now indispenseable. I'd say forget about Keil, never again. Title: Re: ARM rvds toolchain eclipse plugin Post by: metal on January 25, 2016, 07:41:49 19:41 how do you create linker scripts and are startup files available? Are you using coocox? can you give more info about your chain and how to duplicate it? Are you using HAL or just stdperiph?
Title: Re: ARM rvds toolchain eclipse plugin Post by: DarthPic on January 26, 2016, 06:14:55 18:14 I use system workbench for STM32 that is 100% compatible with stm32f4 and stm32f7.
It's eclipse based and everything work very fine ;D You can get info here : http://www.openstm32.org/System+Workbench+for+STM32 (http://www.openstm32.org/System+Workbench+for+STM32) It's free and like dotm i no more use Keil MDK :D Cheers. Title: Re: ARM rvds toolchain eclipse plugin Post by: metal on January 26, 2016, 10:33:18 22:33 Actually, I followed this book (https://leanpub.com/mastering-stm32) on how to setup arm gcc environment. I also used his python script (http://www.carminenoviello.com/en/2015/11/02/quickly-import-stm32cubemx-project-eclipse-project/) to import CubeMX project to eclipse. It compiles OK, but apparently there is sth wrong in his work. Once I start debugging, I can see that trace_printf has issues like the inability to resolve type "va_list", also the debugger runs without stopping, if I stop it, it lands on trace_printf, I read somewhere that this function needs to be manually implemented.
Any body knows what's going on? Title: Re: ARM rvds toolchain eclipse plugin Post by: dotm on January 31, 2016, 03:53:43 15:53 hey metal.
.) can you provide information about your debugger interface? .) have you done everything to enable semihosting? (probably this is the problem) Title: Re: ARM rvds toolchain eclipse plugin Post by: metal on January 31, 2016, 07:07:56 19:07 I should consider only SRAM1 and SRAM2 on STM32F407VGT6. When I first opened the datasheets, I found a table that shows 192KB for this MCU. When I defined the correct RAM size, all went smoothly.
Title: Re: ARM rvds toolchain eclipse plugin Post by: Buddy on February 01, 2016, 05:23:07 05:23 What's wrong with Keil IDE?
Any function you need to use but cannot find? Title: Re: ARM rvds toolchain eclipse plugin Post by: metal on February 01, 2016, 08:57:01 08:57 It's a personal preference, nothing wrong with learning how to use GCC and eclipse. I know how to use keil and debug with it, but I just don't like it.
I used WinAVR since 2008, and then it became AVR-GCC. I know how to handle this environment for AVR. ARM is different and needs a bit more work to get started, after all it is a hobby, I am not interested in arguing which is better and why, so your question is answered no need to argue about this matter here. Title: Re: ARM rvds toolchain eclipse plugin Post by: dotm on February 02, 2016, 08:34:29 20:34 What's wrong with Keil IDE? Any function you need to use but cannot find?
some positive things:
EDIT: I added a picture for you to see a little bit of the editor greatness of eclipse. 1) a macro expansion or a peek inside a function or the variable declaration automatically shows when clicking on anything. 2) if you mark something, its occurence is marked, very useful 3) the code outline. you can basically drag and drop complete functions here to sort your code. Title: Re: ARM rvds toolchain eclipse plugin Post by: Buddy on February 11, 2016, 02:52:46 02:52 Hi Dotm, have you used Microsoft Visual Studio + Visual Assist X?
Is it better than Eclipse (I haven't used Eclipse though as I thought it loads slow and sluggish) Thanks. Title: Re: ARM rvds toolchain eclipse plugin Post by: dotm on February 19, 2016, 07:09:29 19:09 @buddy:
I see. This seems to be very advanced indeed. But I would have to manually integrate the compiler and the debugger or not? Title: Re: ARM rvds toolchain eclipse plugin Post by: Beltza on February 20, 2016, 06:44:09 06:44 Try Visual Studio with VisualGDB. It integrates all the necessary stuff.
Title: Re: ARM rvds toolchain eclipse plugin Post by: Buddy on February 20, 2016, 07:43:59 07:43 With all the setup in VisualGDB for Keil and it costs money, I don't think it is good for long term.
Dotm, the Visual Studio does not integrate with Keil. So you need to switch screens when programmings. Title: Re: ARM rvds toolchain eclipse plugin Post by: dotm on February 22, 2016, 04:46:27 16:46 Dotm, the Visual Studio does not integrate with Keil. So you need to switch screens when programmings. I'm done with Keil anyway. I dont know, may I should give it a try? Will it work with doxygen and git? Its at least 499 + 99 + 89 Dollars for Visualstudio/Visualassist/VisualGDB. Could be that its really good then I get hooked and spend money (a lot compared to eclipse which is free). Title: Re: ARM rvds toolchain eclipse plugin Post by: Beltza on February 23, 2016, 06:05:38 06:05 Use the free edition of Visual Studio.
Title: Re: ARM rvds toolchain eclipse plugin Post by: Git on April 08, 2016, 04:49:29 16:49 Can anybody, please, give me or point me to clear step by step instructions for setting up GCC for ARM (eabi, whatever) and Eclipse so I can compile and link from inside Eclipse (ie, need an IDE) on Windows 7. I don't have specific interest in the STM, mainly LPC and ATSAM. I cannot find clear info on this anywhere. Any article I find on GCC or Eclipse seems to assume you have a brain 40 years younger than mine and total recall. Would be most grateful, thanks.
Title: Re: ARM rvds toolchain eclipse plugin Post by: sam_des on April 09, 2016, 06:28:46 06:28 @Git
This might help...Although focused on STM32...nevertheless goes step by step from compiler/Eclipse download to setting up OpenOCD.. Quote http://eraycanli.com/2015/08/19/stm32-gnu-arm-gcc-toolchain-with-eclipse-stlink-and-openocd-debugger/ BTW, anyone have any opinions about Imagecraft Cortex compiler? Seems pretty cheap & support is awesome. In my experiments with demo, generates somewhat inferior code. Also Code::Blocks is is much faster and less resource hungry compared to Eclipse.. _sam_des |
