Title: Dallas Ibutton CRC check in picbasic Post by: antico2 on April 30, 2008, 02:15:42 02:15 Does anyone have developed the code to check the CRC of an ibutton connected via one-wire to a pic port ?
I'm studing how to develop it, there's someone who want speak about ? Title: Re: Dallas Ibutton CRC check in picbasic Post by: ogul on May 01, 2008, 10:45:50 10:45 'org. prg:
'http://www.picbasic.co.uk/forum/showthread.php?t=7533 ;------------------------- Port Assignments -------------------------------- ; PORTB.6 DS18B20 - Data Line ;--------------------------- Setup DEFINE;s ---------------------------------- DEFINE OSC 4 DEFINE ADC_BITS 10 ; Set resolution of conversion DEFINE ADC_CLOCK 8 ; Set clock source (x/FOSC or FRC) DEFINE ADC_SAMPLEUS 50 ; Set sampling time (in uS) ;------------------------ Port Initialization ------------------------------- CCP1CON = %00000000 ; Disable CCP Module SSPCON.5 = 0 ; Disable SSP Module TXSTA.5 = 0 ; Disable AUSART Tx RCSTA.7 = 0 ; Disable Serial Port ANSEL = %01000000 ; Set analog ports to digital mode except RB7/AN6 CMCON = %00000111 ; Turn off comparator OPTION_REG.6 = 0 ADCON1 = %10000000 TRISA = %100000 TRISB = %11110101 ;----------------------------- Debug Settings ---------------------------------- cmd con 254 ; Control byte clr con 1 ; Clear the display line1 con 128 ; Move cursor to home position on line 1 line2 con 192 ; Move cursor to home position on line 2 line3 con 148 ; Move cursor to home position on line 3 line4 con 212 ; Move cursor to home position on line 4 ; ----------------------------- Port Aliases --------------------------------- DSDataPin var portb.6 ;---------------------- Miscellaneous Variables ------------------------------ i var byte ; Loop counter x var word ; Variable for calculations DataBit var bit ; Bit shift variable dummy var word ; Dummy variable for DIV32 function DataByte var byte ; Byte to perform CRC calculation on DQ var byte[9] ; 9 Byte Arrray for DS18B20 data CRCCalc var byte ; Calculated CRC value NegBit var rawtemp.Bit11 ; +/- indicator: 1 = < 0ºC RawTemp var word ; Raw Temperature SignC var byte ; +/- Sign for celcius temperature SignF var byte ; +/- Sign for fahrenheit temperature TempC var word ; Temperature in ºC TempF var word ; Temperature in ºF TempK var word ; Temperature in Kelvin CRCError var byte ; Temperature Sensor CRC Error Flag ;--------------------------- Main Program Loop ------------------------------- main: gosub ReadDS18B20 lcdout cmd,line1,SignC,dec3 TempC/100,".",dec2 TempC//100,223,"C" lcdout cmd,line2,SignF,dec3 TempF/100,".",dec2 TempF//100,223,"F" lcdout cmd,line3," ",dec3 TempK/100,".",dec2 TempK//100," K" goto main ;---------------------------- Read DS18B20 Sensor ------------------------------ ReadDS18B20: owout DSDataPin,1,[$CC,$44] ; Tell sensor to start a temperature conversion owout DSDataPin,1,[$CC,$BE] ; Tell sensor you want to read the temperature owin DSDataPin,0,[STR DQ\9] ; Receive temperature from the sensor RawTemp.Byte0 = DQ[0] ; Extract the temperature portion and put it in its one word variable RawTemp.Byte1 = DQ[1] gosub GetCRC ; Calculate the CRC for comparison gosub ConvertCelcius ; Convert temperature to ºC gosub ConvertToFahrenheit ; Convert temperature to ºF gosub ConvertToKelvin ; Convert temperature to K return ;------------------------ Calculate the CRC from Byte 9 ------------------------ GetCRC: for x = 0 to 7 ; Get CRC for each of the 8 bytes DataByte = DQ
next x ; Repeat until all bytes are done if DQ[8] <> CRCCalc then ; Do the CRC values match? CRCError = 1 ; Set flag indicating a problem with this sensor else CRCError = 0 ; Set flag indicating no problem with this sensor endif CRCCalc = 0 ; Reset CRC calculation variable return ;--------------------- CRC Bit Calcuation Method ------------------------------- CalcCRC: for i = 0 to 7 ; Do for all 8 bits in DataByte DataBit = CRCCalc.0 ^ DataByte.0 ; XOR bit0 of DataByte and CRC DataByte = DataByte >> 1 ; Position DataByte for next bit test if DataBit = 0 then Shift ; If test bit not set, just shift CRCCalc CRCCalc = CRCCalc ^ $18 ; If set, account for EXOR feedback shift: CRCCalc = CRCCalc >> 1 ; Shift right the CRCCalc byte CRCCalc.7 = DataBit ; CRC bit 0 to bit bucket next i ; Data bit rotates into CRC bit 7 return ;--------------------------- Convert to Celcius -------------------------------- ConvertToCelcius: if negbit = 1 then SignC = "-" else SignC = "+" endif if SignC = "-" then dummy = 0 RawTemp.Byte0 = RawTemp.Byte0 ^ 255 RawTemp.Byte1 = RawTemp.Byte1 ^ 255 dummy = 625 * RawTemp + 1 TempC = DIV32 100 else dummy = 625 * RawTemp TempC = DIV32 100 endif return ;------------------------ Convert to Fahrenhiet -------------------------------- ConvertToFahrenheit: if SignC = "+" then SignF = "+" dummy = TempC * 18 TempF = div32 10 TempF = TempF + 3200 else TempF = (tempc + 5000) * 900 TempF = DIV32 500 if TempC => 1778 and SignC = "-" then TempF = TempF - 12200 SignF = "-" else TempF = 12200 - TempF SignF = "+" endif endif return ;-------------------------- Convert to Kelvin ---------------------------------- ConvertToKelvin: if SignC = "-" then TempK = 27315 - TempC else TempK = tempC + 27315 endif return |
